fireworks galaxy under severe light pollution
5 replies to this topic
#1 joelin
joelin
  • Loc: Saratoga, CA
Posted 20 August 2019 - 12:30 AM
So I did the area around the fireworks galaxy yesterday, mag 18.5 skies...
15 frames of 30 seconds each
80mm f/6 SV80ST refractor, ASI1600MC-cool at 0C
so yeah 7.5 minutes under really bright skies...does it look ok or can i do better under those constraints?
Here is a closeup of the galaxy
Edited by joelin, 20 August 2019 - 12:31 AM.
  • Ptarmigan, PirateMike, artem2 and 2 others like this
#2 jerahian
jerahian
  • Loc: Maine
Posted 20 August 2019 - 01:22 AM
I know what Saratoga is like...I used to live in SF :)  Here is what I would do if I were you:
1) Cool you camera to -15 (reduces your read noise)
2) Up your exposure to 60s
3) Set your gain to 75, offset 10
4) Take about 150 exposures
5) Dither every 3 frames (2 would be better if you have the time)
...7.5 mins is not nearly enough.
Also, at some point, you might want to look into what is going on with your stars; they seem streaky along the 10-4 o'clock line.  What mount are you using?
GL&CS,
Ara
  • elmiko and PirateMike like this
#3 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 20 August 2019 - 03:39 AM
Looks good! Just need a load more subs!!!!  Its a great field.
Just to be pedantic (but why not) cooling reduces dark current and hence shot noise from that dark current; it doesnt reduce read noise. You'll need different darks if cooling. I expect you know that!
  • PirateMike likes this
#4 jerahian
jerahian
  • Loc: Maine
Posted 20 August 2019 - 08:03 AM
  • happylimpet likes this
#5 bobharmony
bobharmony
  • Loc: Connecticut, USA
Posted 20 August 2019 - 08:07 AM
Agreed - this is a good start, and yes, you will do better with more subs and more time.  Great recommendations thus far on cooling and dithering.  Nice framing, BTW!
Bob
#6 joelin
joelin
  • Loc: Saratoga, CA
Posted 20 August 2019 - 12:32 PM
actually i did dither...im sure the noise would be much worse otherwise
as for the messed up stars....i blame that on the field flattener
