New Meade 26mm MWA
equipment eyepieces Meade optics
39 replies to this topic
#1 Ronofthedead07
Ronofthedead07
  • Loc: New Hampshire
Posted 20 August 2019 - 02:46 PM
So Meade appears to be offering a new 100-degree MWA eyepiece in a 26mm focal length (#607019). Meade does not appear to have provided a whole lot of information but are claiming a 7-element design with 25mm of eye relief. Price is $289.99.
At this focal length the only real comparable eyepiece is the 8-element Explore Scientific 25mm 100* which retails for $749.99 (currently on sale for $599.99). I haven't used the ES but it seems to receive somewhat mixed reviews, so I wonder how this new Meade may compare.
#2 dan_h
dan_h
Posted 20 August 2019 - 04:29 PM
A 100 degree field for a 26mm focal length would require a field stop very nearly 62mm diameter.
How does one fit this in a 2" barrel?
I would expect edge problems of all sorts.
dan
#3 25585
25585
  • Loc: In a valley, in the UK. Dark end of the street.
Posted 20 August 2019 - 05:04 PM
Same optics as the ES?
#4 SeattleScott
SeattleScott
Posted 20 August 2019 - 05:54 PM
At half the price? Not likely. Pretty sure the ES has more than 7 elements.
Scott
  • faackanders2 likes this
#5 DRodrigues
DRodrigues
Posted 20 August 2019 - 06:52 PM
These are similar to the Omegon Panorama II  https://www.cloudyni...n-panorama-ii/ so have <90º AFOV.
I'm curious about the ER mentioned and would like to see if it allows viewing all AFOV with glasses on - the 20mm ER mentioned for the 15mm version didn't...
  • 25585 likes this
#6 Riccardo_italy
Riccardo_italy
  • Loc: Italy
Posted 21 August 2019 - 09:10 AM
dan
(26*100)/57.3=45.4mm
That's in theory!
  • Jon Isaacs and faackanders2 like this
#7 dan_h
dan_h
Posted 21 August 2019 - 01:23 PM
That's in theory!
My bad. Thank you for the correction.
dan
#8 Vla
Vla
Posted 21 August 2019 - 04:57 PM
It's not. The 57.3 route is accurate only for small angles, much smaller than 100 (which btw has negative tangens). Exact field stop diameter is given by 2f*tan(GFOV/2), where "f" is the focal length and GFOV the geometric field of view,  i.e. field with zero distortion. Since we only have AFOV, which is inflated by distortion, we could approximate the field stop by assuming 20% distortion, which would make the GFOV about 83 degrees. The corresponding field stop would be 2f*tan41.5=46mm.
Edited by Vla, 21 August 2019 - 06:01 PM.
#9 Vla
Vla
Posted 21 August 2019 - 06:00 PM
The 7-element Nagler-like eyepieces can have excellent correction. An example by Smith/Ceragioli/Berry in their book has flat field and 0.77 Strehl in the green 40 degrees off. With little modification, perhaps some mild field curvature, it can go close to 100. Its disadvantage is the size.
#10 dan_h
dan_h
Posted 21 August 2019 - 07:54 PM
Thank you. I had used the 2f*tan(GFOV/2) and for 100 degrees it yields a field stop of 61.96mm.  I hadn't realized how significant the distortion is.
dan
#11 Vla
Vla
Posted 22 August 2019 - 07:01 AM
Distortion in a 100-deg unit is probably more than 20%. The "Modern Nagler" mentioned above has 24% 40 degrees off axis, and it's (very) unlikely that a similar design will have less at 50 degrees. Which implies  that the field stop is smaller than 46mm.
#12 Jon Isaacs
Posted 22 August 2019 - 12:35 PM
My thinking:
AFoV is something that can be directly measured. Any scaler relationship between the focal length, the field stop and the AFoV will require a fudge factor which accounts for distortion.
Interestingly, if one uses the relationship:
AFoV = 57.3 deg/rad x Focal length / Field stop, eyepiece's like the 21 mm and 13 mm Ethos, the 20 mm ES 100 degree, work out to within a degree or two of 100 degrees.
#13 dan_h
dan_h
Posted 22 August 2019 - 04:34 PM
My thinking:
I did some research. As I understand it, that formula is derived from the formulas for the image size from the objective.
Basic trigonometry gives, Primary  Image size = tan(FOV) X Objective FL.
The Objective FL is equal to EPFL X Magnification,  and magnification is defined as AFOV/FOV
So Image Size or Field Stop size = tan(FOV) X EPFL X (AFOV/FOV)
At small angles (<0.1 radians),  tangent very nearly equals angle so the factors Tan(FOV) and FOV cancel leaving
Image Size or Field Stop = AFOV * EPFL and we need to add the conversion factor of 57.3 for degrees to radians .
Field stop(mm) = AFOV * EPFL(mm) /57.3  which as you stated, seems to agree with actual field stops.
Working backwards as I originally did, from the AFOV using EPFL,  results in an apparent size for the field stop, not the actual size.
dan
Edited by dan_h, 22 August 2019 - 04:35 PM.
#14 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 22 August 2019 - 05:31 PM
That's in theory!
Correction.  100° would require 61.97mm of field stop, but that is for 0% distortion, which doesn't correspond to reality.
With distortion, it could be as small as 44.6mm (45.4 calculated).  That figure is the 13mm Ethos field stop x 2 for the 2 x 13mm focal length, assuming equal distortion.
However, what are the odds it would be better than the 8 element ES 25mm?
The ES eyepiece has noticeable vignetting and chromatic aberration of the exit pupil, and astigmatism in the outer 10-15% of the field at f/5-f/6 (probably worse at faster
f/ratios, but I have no experience there with this eyepiece)
Now, if the Meade is, indeed, only around 90°, it could be quite OK.  We need some test reports.  Who's the guinea pig?
Edited by Starman1, 22 August 2019 - 05:36 PM.
  • Jon Isaacs and ewave like this
#15 Miranda2525
Miranda2525
Posted 22 August 2019 - 07:05 PM
Link?
#16 nicoledoula
nicoledoula
Posted 22 August 2019 - 09:20 PM
https://www.meade.co...-eyepieces.html
  • Miranda2525 likes this
#17 Miranda2525
Miranda2525
Posted 24 August 2019 - 09:07 AM
https://www.meade.co...piece-26mm.html
Ahhh, ok, I see it now.
That will be a hard task. I have a 23mm Axiom LX which is 84.5 degrees. IMO, the 26mm is a stretch of the imagination. lol.
  • nicoledoula likes this
#18 25585
25585
Posted 24 August 2019 - 03:48 PM
Waiting for a UK dealer to stock one.....
#19 Ronofthedead07
Ronofthedead07
Posted 01 September 2019 - 08:29 PM
Thanks for the input, everyone. I am skeptical of some of the claims, so it will be interesting to see how it fares.
I'm sticking to 82s for the time being!
#20 stargazer193857
stargazer193857
  • Loc: Southern Idaho
Posted 23 November 2019 - 08:42 AM
Provided a 60 deg eye 20mm has a 20mm field stop,
Tan(50)/tan(30)x26 = 53.7mm.
So, 10% distortion could make a smaller field look 100 deg.
I think I'll stick with cleaner 82 deg eyepieces.
#21 Starman1
Starman1
  • Loc: Los Angeles
Posted 23 November 2019 - 02:01 PM
It looks like the other MWAs have apparent fields in the 88-92° range, which is what I'd expect for this one.
#22 stargazer193857
stargazer193857
Posted 23 November 2019 - 03:42 PM
I'm OK with 90 degrees. I wonder how the edge performance compares to 82 deg Meades.
The massive size of the 100 does make the eye relief a tad more believable.
Is the 82 deg 24mm Meade still for sale? I've not seen it on Agenaastro in a while. At least they have the 20mm.
#23 Starman1
Starman1
  • Loc: Los Angeles
Posted 23 November 2019 - 04:30 PM
Looks like Meade is O/S
https://www.meade.co...ngle.html?cat=8
#24 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 23 November 2019 - 04:57 PM
I think Meade killed the 24mm and 30mm UWA a while back.
#25 Ronofthedead07
Ronofthedead07
Posted 23 November 2019 - 05:37 PM
They did, but the discontinued focal lengths do come up used from time to time (4.7, 6.7, 18, 24 and 30, I believe).
They do still sell the 5.5, 8.8, 14 and 20 new.
I suppose the MWAs aren't a terrible deal as 90-ish degree eyepieces with longer eye relief.  There doesn't seem to be much like that outside of the ES 92s.
  • 25585 and nicoledoula like this
Also tagged with one or more of these keywords: equipment, eyepieces, Meade, optics
