PHD with ZWO ASI Mini 120
4 replies to this topic
#1 archer1960
archer1960
  • Loc: Southern New England
Posted 21 August 2019 - 08:06 PM
I am having trouble with PHD and my ASI Mini 120. The problem is that I can't get a real image to show in PHD. All I get is a screen full of noise and jagged vertical lines, no matter what I do with exposure, gamma or gain.
The same camera works fine with SharpCap and ASICAP, so I don't think it's the camera itself. I also just installed tried MetaGuide (which I had never tried before), and it shows a good image too.
I updated all the drivers (native and ASCOM), and nothing changed. Any idea what I should try? I like PHD, and have had good luck with it in the past, but when I got the new guide camera, I've seen this issue about 90% of the time.
Suggestions?
  • elmiko likes this
#2 elmiko
elmiko
  • Loc: Arizona
Posted 21 August 2019 - 08:25 PM
Have you done a dark frame library in Phd2? Really easy to do it will talk you through it. I had the same thing happen to me when I first started using Phd2 . Give it a try.
  • Aaron_tragle likes this
#3 jerahian
jerahian
  • Loc: Maine
Posted 21 August 2019 - 09:58 PM
Hmm, I feel like I've come across this before.  If you haven't already, try switching from one driver to the other (i.e. native to ASCOM or vice versa, depending on which you are currently trying with).  Also, make sure you have MONO8 selected as the Image Type in the driver settings.
#4 archer1960
archer1960
Posted 22 August 2019 - 06:29 AM
Yes, I've tried it both with and without a dark library. I've run into strange things with the darks before.
Thanks for the suggestion!
  • elmiko likes this
#5 archer1960
archer1960
Posted 22 August 2019 - 06:30 AM
I'll give that a try; thanks!
