what does Celestron's 0.7 reducer do to an edge hd?
6 replies to this topic
#1 Benni123456
Benni123456
  • Loc: Munich, Germany
Posted 22 August 2019 - 01:42 PM
I have an edge hd 800. Even if I try to collimate the scope with reducer perfectly, I see color dependent distortions at the edges (i.e. different filters show different star shapes). Without the reducer, this is not the case and it is not a problem of the filters, since my refractor does not show this.
So I wonder what the reducer does to the edge hd optically?
Since there are people here who have put their telescopes into interferometers, I wonder whether there are people here who have tested the scts with reducer and can tell what it does to the optics, and whether there are ways to optimize image quality in the field (different corrector rotation, different distances, different focus positions for the filters etc.).
Best regards
Edited by Benni123456, 22 August 2019 - 01:42 PM.
#2 John Miele
John Miele
  • Loc: North Alabama
Posted 27 August 2019 - 04:50 PM
Dunno benni but I and many others have seen this problem. The .7 reducer is quite disappointing in this regard. I need a heavy crop to remove the bad corner stars. Celestron should be embarrassed by this lateral color smear...
  • Benni123456 likes this
#3 freestar8n
freestar8n
    Vendor - MetaGuide
Posted 27 August 2019 - 05:44 PM
I wouldn't expect any add-on reducer not to need some tweaking of collimation after attachment.  The tolerances are very tight and it is no big deal anyway.  You should always collimate for the actual system you are using - and there is no need to collimate first at f/10 and then at f/7 - if all you intend to use is f/7.
The EdgeHD8 reducer appears to have challenges compared to the other sizes.  It's not trivial to take a well corrected and flat field and reduce it down - that's why they are expensive and have large lenses.  Try it at different spacings and perhaps you will find improvement.
But the challenges people seem to have with the 8" reducer don't seem to be a factor for the larger sizes.
I have used EdgeHD8 at f/10 but not with the reducer - so I have no experience with it.  I use EdgeHD11 with reducer and it takes some care to get the field corrected well - but I have good results with 8300 ccd and asi1600.  And that is without any special changes to a stock OTA.  There are others with EdgeHD14 and reducer who get similar results with larger sensors - and no realignment of the internal optics or corrector.
Frank
  • jdupton likes this
#4 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 27 August 2019 - 10:59 PM
Best regards
Did you not start another thread on exactly the same topic? I remember having the same conversation with you there. You really don’t seem happy with your EdgeHD 8. As I mentioned these scopes are made to a price point, if you are seeking perfection you need to spend a bit more.
#5 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 28 August 2019 - 09:09 AM
The EdgeHD 8" is fine by me.  Well-corrected flat field.
The 0.7x reducer is just that.  A reducer.  It gives you more options for your eyepieces.  The EdgeHD 8" is already corrected for coma and has a flat field, so don't expect the reducer to do anything else but reduce.
I see no optical problems induced by the 0.7x reducer.  But then I'm 100% visual.  I don't do AP.  The only sensors I use are my retinas.
Edited by Sarkikos, 28 August 2019 - 09:10 AM.
  • gfstallin and Glass Man like this
#6 Benni123456
Benni123456
Posted 23 September 2019 - 12:55 PM
Hi sorry, that i did not reply until now. I was a bit occupied with my phd thesis.
I did now do some trial and error and experimented with my setup.
It turns out that there is one problem:
If you screw some imaging train on your sct, it takes a few set of turns.
But the reducer takes a different set of turns to get fixed.
This means if you collimate your edge with your imaging train (which is extremely sensitive to tilt), putting a reducer in between will have your imaging train rotated, and with it, the tilt goes to another direction, which implies that one has to recollimate.
However, in this post I show a perfectly, or almost perfectly collimated image for the red wavelength:
https://www.cloudyni...ctly/?p=9662448
So, at least in red, it is possible to get round stars for the image circle of an asi 1600.
In blue, I get this (the images where taken just 240 seconds after each other)
https://www.cloudyni...ctly/?p=9662464
I have no idea where this optical problem comes from...
Perfect image in red but comets in blue.....
I think I have the correct sensor reducer distance.....
#7 Benni123456
Benni123456
Posted 23 September 2019 - 12:58 PM
Frank
Hi frank, do you get good results for all colors?
If so, then I may just buy an edge 9 and this problem gets away...
I now figured that most of my problem came from a tilt in the adapter plate of my off axis guider.
I could remove this by buying a newer adapter plate....
So now its only the blue and green color with the reducer that I don't like. The red wavelength is almost perfect.
Edited by Benni123456, 23 September 2019 - 12:59 PM.
