Compatibility of Orion Astroview Single-Axis Drive with CG4
3 replies to this topic
#1 ngc6352
ngc6352
  • Loc: Boise, Idaho
Posted 22 August 2019 - 04:32 PM
Does anyone know if the single-axis drive for the Orion version of the EQ3 is compatible with the Celestron CG-4?
I know it will "fit", but is the drive rate OK (worm wheel teeth/size)?  I can't get an answer out of Orion and Celestron's
"Live Chat" takes you to the "Submit a Ticket" page.  I don't really want to buy one and send it back, paying a $10 fee
if it doesn't work.  I have a dual axis but it looks like a 5th grade science project that will very likely break (quickly) in use.
#2 fcathell
fcathell
  • Loc: Tucson, AZ
Posted 22 August 2019 - 04:52 PM
These mounts come from the same manufacturer I'm pretty sure, so if the Orion drive motor bracket fits the CG4 mounting hole, I would say yes. I have the old Astroview mount and I had an old Celestron version of this mount, but I'm not sure if Celestron labeled it a CG3 or CG4.  In any case the RA drive worked fine on both.
Frank
#3 tmaestro
tmaestro
  • Loc: West of Houston, Texas
Posted 23 August 2019 - 07:51 AM
I have Celestron CG4 dual axis motors on my Orion EQ3 and it works great, they are the same in different colors.
Edited by tmaestro, 23 August 2019 - 07:51 AM.
#4 malachirebekah
malachirebekah
Posted 27 August 2019 - 07:21 PM
I have the Orion EQ3 single axis drive mounted on my CG4, and it tracks perfectly.
