Red Light (Flashlight) Recs?
4 replies to this topic
#1 smilingmoose
smilingmoose
  • Loc: Colorado
Posted 22 August 2019 - 10:20 PM
I have a gift card for Amazon and was thinking about getting some light for the field. Any recommendations?
#2 scadvice
scadvice
  • Loc: Lodi, California
Posted 22 August 2019 - 10:43 PM
I finally tried a headlamp with a red side. This one.
https://www.amazon.c...0?ie=UTF8&psc=1
  • Battery last forever.
  • It has both red and white light and separate buttons for them (You just have to remember which button is which. lol.gif )
  • I bought another because it last so long (4 or more nights) I forget to charge it so I keep one on standby.
  • Hands are free.
Dislikes
  • With gloves you have to take them off to turn it on and off. So I don't bother to turn it off since it last so long I just leave it on.
  • It has has a flashing mode which is a pain at times.
#3 B 26354
B 26354
  • Loc: Southern California semi-desert (NELM mag 5.3)
Posted 23 August 2019 - 01:20 AM
For the past two years, I've used this:
https://www.amazon.c...r/dp/B01MRRF9PJ
...and this:
https://www.amazon.c...r/dp/B01HZ7Y2KE
...which does fit the LD12.
What's really nice, is that when used with the rechargeable battery, the Medium setting (30 lumens) is good for an entire three-night session, if used "normally". Under dark skies, with full dark-adaptation, it's also somewhat bright, though... so I very rarely use it, unless I'm looking for something on the ground. The Low setting on the LD12 is wonderfully dim however (only 5 lumens), and on that setting, my dark-adaptation is perfectly preserved, and the battery charge lasts for many days of normal all-night use.
I've used dozens of inexpensive and moderately-priced "small" LED flashlights over the years, and without exception, the switches on them have invariably failed within six months. I now have four Fenix lights: one LD12 and three smaller and less-expensive E12s -- one of which is four years old, and is used many times every day -- and all of them still perform flawlessly. And Fenix flashlights have a "limited lifetime warranty".
Edited by B 26354, 23 August 2019 - 01:24 AM.
#4 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 23 August 2019 - 02:14 AM
I've been using one of these for 20+ yrs.  The dimmer feature is nice.  Neither the red nor white settings are extremely bright, but that is probably a good thing.
https://www.amazon.c... red flashlight
This one is red only:
I guess this is their latest version:
https://www.amazon.c...ystems starlite
They are expensive compared to other lights, but considering mine has lasted 20+ yrs, I can't complain too much.  I think I've taken it apart 2 or 3 times to clean out the pocket dust, but otherwise has been pretty much flawless.    (On the other hand I have a box full of dead $10 to $30 headlamps -- most of them seem to fall apart after a couple years.)
Edited by ngc7319_20, 23 August 2019 - 02:31 AM.
#5 james7ca
james7ca
  • Loc: San Diego, CA
Posted 23 August 2019 - 02:45 AM
Here is a tread on CN that has nearly 300 posts about red lights for astronomy related activities, it should answer all of your questions and gives lots of recommendations for products:
  https://www.cloudyni...e/#entry8652225
In any case, I wouldn't recommend anything that can't use rechargeable batteries. Otherwise, you could end up spending a small fortune on disposable batteries. Buy a few sets of Sanyo Eneloop batteries and a good charger and it will pay for itself in the first year or two of use.
Edited by james7ca, 23 August 2019 - 02:53 AM.
