Explore Scientific Red-Dot Finder Fix
3 replies to this topic
#1 Sky Muse
Sky Muse
  • Loc: Mid-South, U.S.
Posted 22 August 2019 - 10:43 PM
Got a wonky, shaky, jiggling, wiggling Explore Scientific red-dot?  I did, past-tense, but I didn't throw it away, although perhaps I should've.  But no, I "fixed" it, and it was easy.
I brought out my box of Harbor Freight springs...
...picked out of two of these...
...cut two out of each spring, two longer, and two shorter...
The longer for the azimuth...
...and the shorter for the altitude...
One spring is positioned on each side of that tab arrowed in yellow.
After the clamping-plates are re-installed, you can grab the plates and shake the very devil out of the finder, with no more wonkiness, and with both axes fully adjustable.
Trial-and-error will be involved when sizing the springs, and for just the right amount of tension.  Also, be careful not to strip out the plastic adjustment-threads when incorporating the springs.
Thank you for looking.
  • Joe1950 and Chris Y like this
#2 CeeKay
CeeKay
  • Loc: Vancouver, WA
Posted 23 August 2019 - 06:35 PM
SkyMuse - what did you do to get the knobs off the screws?  Were they screwed in or were they glued in place?
Such a simple fix for the RDF...
Chris
  • Sky Muse likes this
#3 Sky Muse
Sky Muse
Posted 23 August 2019 - 07:31 PM
Chris
The plastic, knurled knobs screw on, and it's best to torque them a bit after they come to a stop.  I tested them both afterwards, and they didn't loosen.
  • CeeKay likes this
#4 Sky Muse
Sky Muse
Posted 23 August 2019 - 07:43 PM
I ran into a problem when wanting to attach the finder to a plastic, Vixen-type stalk.  The clamping-plates would not compress inward enough to grab the stalk's whatchamacallit firmly enough...
The problem was that the plates' lower, wider ledges were too wide, so I ground both and removed about a fourth to a third of their widths.  Problem solved, and here the finder is attached to the 5" Bird...
I will not be using any ES/Meade finder-bases with any of my telescopes; Vixen-type all the way rather.
Edited by Sky Muse, 23 August 2019 - 10:52 PM.
