Zeta Sagittarii
5 replies to this topic
#1 Frisky
Frisky
  • Loc: Austin, Minnesota
Posted 23 August 2019 - 02:28 AM
I went to the bottom star in the Teapot's handle and tried to split Zeta Sagittarii. The two main components are very bright, below the trees, and the sky conditions were only fair. They wanted to split, but I couldn't do it. It looked like a bright blue star (bluest I've seen) mixed with a red star! It was neat watching that blue and red go across the field of view! Now, the problem with Gamma Cas is you have a big and bright main star with a small, dim companion near to it. With Zeta Sagittarii, you have two bright stars hugging each other! Some of the color I saw might have been due to atmospheric dispersion. Anyone split this double?
Joe
  • R Botero likes this
#2 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 23 August 2019 - 02:36 AM
No, but it sounds beautiful. It's a tight pair (triple) at less than 0.5" arc (P.A. 239.1 SEP 0.48 MAG 3.27,3.48). I will give it a look next time I am out. You bet! smile.gif
Edited by Asbytec, 23 August 2019 - 02:36 AM.
  • Frisky likes this
#3 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 24 August 2019 - 05:24 AM
Wow! Didn't know about that one! Sadly, it's very low in my sky and even an elongation would be a major feat from here.
Clear skies!
Thomas, Denmark
  • Frisky likes this
#4 fred1871
fred1871
  • Loc: Australia
Posted 24 August 2019 - 08:13 AM
Zeta Sagitarii is a short period binary, orbit taking 21 years. There's also a wide optical companion of mag 10.6. The binary is resolvable with middling apertures when widest, nearly equal stars at 0.6". They were near that separation a few years ago, but the system is now closing. The ephemeris gives 0.42" (interpolated) at the present date. So a C11 might give a Dawes split in good seeing. An 8-inch at high power in good seeing should give a rod effect; Dawes for an 8-inch is 0.57". Elongation can be detected down to 0.5-Rayleigh, sometimes closer; 0.5-R is 0.34" for an 8-inch.
My first observation of Zeta Sgr was decades ago with a 6-inch Newtonian, at a time when the separation was 0.6", around the maximum. At 400x it was an elongated notched pair.  A revolution and a bit later with a 7-inch apo it was seen as a figure-8 pairing at 330x.
It will be a number of years before we see it get back to 0.5" or 0.6" and therefore reasonably accessible to medium apertures. Mid last year it was at 0.50". It won't get back to that separation until 2034. It will be in the 0.5" to 0.6" separation range from then until 2039.
The discovery designation is HDO 150, and the discovery was made in 1867 by Joseph Winlock with the Harvard 15-inch refractor.
Incidentally the stars are Sirian type (A), so both are white, but may look pale yellow to older eyes or through dust or haze.
  • Astrojensen, flt158 and Frisky like this
#5 Frisky
Frisky
Posted 24 August 2019 - 05:08 PM
I think the bright blue and reds I saw were due to the atmosphere. Kind of like the times when Saturn was low and leaving us for the year, and I saw it as red, white and blue, lol!
Joe
#6 fred1871
fred1871
  • Loc: Australia
Posted 02 October 2019 - 08:27 AM
Back to Zeta Sagittarii. Looked at it tonight for the first time in quite a while. Used the 140mm refractor. I had another look at the ephemeris and I think I have a typo - or maybe a slip of the calculator - in my note above. After careful assessment of the ephemeris (from the Grade 1 orbit) current separation is 0.45", not 0.42".
So I thought I'd use it for a break-the-0.5Rayleigh-barrier attempt. Seeing was better than various recent nights. I was pleasantly surprised to find a very slight elongation at 400x, and more obvious (though still slight) at 570x. Other nearby stars (single) did not show anything but neat'n'round. So, that's about 0.45-Rayleigh, my best yet for the particular scope. Previous best with it was with Zeta Bootis a while back when it was at about 0.48", likewise an equal pair, bright, and using 400x/570x.
If I get opportunity (another steady night) I will try it with the Mewlon 210. Rayleigh on that is 0.66", Dawes is 0.55". So it won't be a clean split, but a more obvious elongation. At 0.45" it will take a 10-inch for a Dawes tangent discs "split", or a 12-inch for a Rayleigh criterion split. That's now. By next year it will be closer still. By September 2020 about 0.33". It changes fairly quickly once it gets well into the closing swing. Minimum separation, below 0.20", appears to be in 2022-23. After that it widens again.
By the  way, Zeta Sagittarii is one of the 175 doubles featured in the new Argyle book, An Anthology of Visual Double Stars (#144). Orbit diagram and ephemeris given there.
  • R Botero and Nucleophile like this
