2" Focus Tube Extender
6 replies to this topic
#1 patindaytona
patindaytona
Posted 23 August 2019 - 08:08 AM
2" Tele-extender.   How does this work? The narrower end is 2", right?
It that end fits into the focuser, then wouldn't the other end appearing wider be too wide for a 2" eye piece?
Can i also use this to fit the 1.25" adapter into it for the 1.25" eye pieces?
#2 S.Boerner
S.Boerner
  • Loc: Chesterfield, MO
Posted 23 August 2019 - 08:16 AM
Look at the picture here and you'll see how it works:
     https://agenaastro.c...n-x2c-0008.html
You can put a 2" to 1.25" adapter into the extension tube for 1.25" eyepieces.
     https://agenaastro.c...r-acf-2125.html
#3 RAKing
RAKing
  • Loc: West of the D.C. Nebula
Posted 23 August 2019 - 08:18 AM
If you are asking about the 2-inch Televue extension, it was designed to fit in front of the diagonal or eyepiece.  The front end goes into the focuser and the back end allows a 2-inch eyepiece (or star diagonal) to be fitted.
Yes, you could also put a 1.25" adapter into the back for smaller eyepieces.
Ron
#4 wrvond
wrvond
  • Loc: West Virginia
Posted 23 August 2019 - 08:22 AM
The outside diameter of the extender is going to be the same as your focuser tube.
In this picture the part with the gold label is the extender:
IMG 1872
#5 patindaytona
patindaytona
Posted 23 August 2019 - 09:04 AM
Thanks, I kind of get it. The part that goes into the focus tube is 2" wide just like an eye piece is, right?
And even though the wider end of the extension appears wider than 2",  the "inside diameter" is still 2", is that it?
#6 zxx
zxx
Posted 23 August 2019 - 09:27 AM
I can remove the lens from my 2" barlow and have a 2" extension
#7 S.Boerner
S.Boerner
Posted 23 August 2019 - 10:03 AM
Yes, that is correct.
