HELP with rasa 8” and qhy163 cameras distance and spacers
6 replies to this topic
#1 Marco Prunotto
Marco Prunotto
  • Loc: Canton du Jura, Switzerland
Posted 23 August 2019 - 09:40 AM
Hi Everyone,
just got the RASA 8” delivered and I have difficulty to find the right distance and spacers to have the qhy163C correctly illuminated. Is there someone here on the forum that had same problem?
could you kindly tell me which spacer you have used/added to the M42 thread that comes with the RASA 8”, would be really appreciated!
Best,
Marco
Edited by Marco Prunotto, 23 August 2019 - 09:41 AM.
#2 Alien Observatory
Alien Observatory
Posted 23 August 2019 - 09:59 AM
If I read the specs correctly, I get the following...
Cam back spacing to sensor = 18mm
Rasa 8 back spacing using the M42 adapter = 25mm
25mm + 18mm = 43 mm spacer
Pat Utah :)
#3 ssantia
ssantia
  • Loc: Illinois
Posted 23 August 2019 - 10:30 AM
Correct if I’m wrong but if I understand correctly the scope has a backfocus of 25mm with the 42mm adapter provided. The camera already uses 18 of those 25 leaving only a 7mm spacer to reach focus.
25mm - 18mm = 7mm
Am I misunderstanding something?
Sam
#4 P_Myers
P_Myers
Posted 23 August 2019 - 10:46 AM
SSanita
you are correct....
#5 redtag
redtag
  • Loc: Tennessee
Posted 23 August 2019 - 12:43 PM
I am using a Baader 7.5 mm extension No. 1508155.  I may have a slight tilt in either the camera sensor or something in the tube but focus seems pretty good to the edges.
  • Rickster and cmooney91 like this
#6 Marco Prunotto
Marco Prunotto
Posted 23 August 2019 - 04:14 PM
many thanks to all of you, will order the Baader spacer!
thanks
Marco
Sent from my iPad using Tapatalk
#7 Alien Observatory
Alien Observatory
Posted 24 August 2019 - 10:07 AM
25mm - 18mm = 7mm
Sam
You are correct, my mistake...Pat Utah :)
