Celestron Binoviewer RAF T2 Adapter Thread Size
2 replies to this topic
#1 Eddgie
Eddgie
Posted 23 August 2019 - 02:30 PM
Can someone that has used one confirm that the 28mm x .75mm thread size is the correct one for the Celestron Binoviewer RAF T2 adapter? I know the thread pitch is .75mm, but I am not positive about the outer diameter for the tread.
https://www.rafcamer...2f-to-m28x0-75m
Edited by Eddgie, 23 August 2019 - 02:31 PM.
#2 REC
REC
  • Loc: NC
Posted 24 August 2019 - 10:25 AM
If the Celestron has the same nose piece as the WO that that RAF adapter works.
#3 Eddgie
Eddgie
Posted 24 August 2019 - 12:53 PM
RAF Lists the correct adapter for the WO as 26mm x .75mm, and I have one of these and I know that it does not fit the Celestron.
The 26mm x .75 also fits the Burgess and I think the Stellarvue, but clearly the front thread on the inexpensive BVs is all over the place.
I have a suspicion that I will need to get a custom adapter or a threaded step ring.
