Manual rotation in SGP
3 replies to this topic
#1 Becomart
Becomart
Posted 23 August 2019 - 07:08 PM
I haven’t used frame and focus much in SGP as I usually find inputting on the cog in the sequence window works well enough. However, tonight, I was imaging something that will only just fit in my frame so had a look at the manual rotation option. I tried to guess the angle and clicked next - still a little off so kept going. I think after a few tries, SGP gave up on me and carried on with the sequence. I was only around 8 degrees out. Am I using this feature correctly or are there tips and tricks I’m missing?
#2 bmhjr
bmhjr
  • Loc: Colorado
Posted 23 August 2019 - 07:35 PM
You can set the tolerance in degrees and also set the number of failed plate solve attempts before it gives up. I think I set the angle to <= 1.5 degrees and fail after 5 attempts. That seems to work for me. I also made a crude scale in increments of 10 degrees that I put around the focuser. It really helps to assist in rotating the correct amount within a few degrees.
  • Becomart and Dynan like this
#3 fetoma
fetoma
  • Loc: Southern NJ
Posted 24 August 2019 - 09:38 AM
I'd love to hear more about this subject, especially concerning how to rotate the camera accurately and not have to plate solve 5 times. Digital level? Degree marks on the focuser?
#4 bmhjr
bmhjr
  • Loc: Colorado
Posted 24 August 2019 - 02:53 PM
I took a strip of gaffers tape and used a marker to make a scale in 10 degree increments.  Wrapped that around the focuser collar.  Nothing fancy.
