Recommendations for USB Cable Extender
6 replies to this topic
#1 TeslaTrek
TeslaTrek
Posted 23 August 2019 - 08:37 PM
I want to move my Starlight Xpress Oculus IP Camera about 30 ' from my observatory.  There is no power where I want to install the camera, only within the observatory.  So the iCron solution would not work.
I've looked at this one that uses ethernet cables:
https://www.cablesto...der-up-to-150ft
But I have no experience with the quality of this product.    Then there are several "active" USB Cable extenders like this one:
https://www.monopric...oduct?p_id=6149
Any recommendations of brand and model?
thanks
jim
#2 Dynan
Dynan
  • Loc: NOLA
Posted 23 August 2019 - 09:20 PM
For about $11, it may be worth a try. If it doesn't work, no big loss.
I went with Tether Tools, one controller and two 16 foot cables, and it worked very well. But the setup cost about $160. Of course I was running the full compliment... DSLR, guide scope, mount.
EDIT: If these are 'powered', you'll have to run power to the female (camera) end...which you said has no outlet available...kind of defeating the purpose.
Edited by Dynan, 23 August 2019 - 09:25 PM.
#3 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 23 August 2019 - 11:05 PM
Why not get a usb over ethernet extender and run the ethernet and a 12v power cable to the camera end. Direct burial ethernet cable is readily available and you could use low voltage direct burial twin lead for the power line. I normally buy my low voltage cable from Home Depot.
  • Dynan likes this
#4 TeslaTrek
TeslaTrek
Posted 24 August 2019 - 08:37 AM
You are right, for $11, I should give it a try.
Actually I already have a 12v cable running through the conduit that powers my Dob telescope's StellarCat, but I did not really want to build another housing for the ethernet extender.
  • Dynan likes this
#5 TeslaTrek
TeslaTrek
Posted 12 September 2019 - 07:26 PM
Update:  I purchased the Monoprice 32' USB extender and it works perfectly for my Oculus all sky camera.  What a surprise!
#6 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 14 September 2019 - 12:50 AM
I am guessing that is USB2.  How about for USB3.0 ?
#7 TeslaTrek
TeslaTrek
Posted 14 September 2019 - 05:33 PM
You are correct.  It is USB 2.
I suspect, or fear,  USB 3 (5 Gbps vice the lowly 480 Mb/s) and now USB 4 (40 Gbps - supposedly) is going to give us plenty of problems as our computers are replaced with newer versions.
