LX-850
53 replies to this topic
#51 stpal001
stpal001
    Vendor-Dark Sky Vacations
  • Loc: West Texas
Posted 18 December 2019 - 04:23 PM
carolinaskies: Same result. I held down the MODE key while applying power and had the same results.
#52 carolinaskies
carolinaskies
  • Loc: Greenville SC
Posted 19 December 2019 - 07:48 AM
Check your HBX plug pins and the pins on the mount to make sure there is nothing corroded or bent.  If you have access to another HBX I would try it to see if the same thing happens.  As well, if you have a computer hookup you could check to make sure it has no issues moving the mount.  Of course also check to make sure your power source is producing enough voltage to the mount.
A reflash of the firmware is also an option if somehow being unattended so long it was corrupted.  My LX200 GPS 16" was in storage for over 7years and I had to reflash it to clear and correct faulty HBX controls.
I've never seen this particular cycling problem with autostar HBX, so can't definitively say it's HBX or mount-internal.
#53 stpal001
stpal001
  • Loc: West Texas
Posted 30 December 2019 - 03:29 PM
Thanks to Carolinaskies but holding down the MODE button didn't accomplish anything.
Here is the sequence of events I am in, which is to say, in a loop.
STATUS      SCREEN DISPLAY
Power off      (Blank screen)
Power On      LX200 GPS
                      © 2001 Meade
                      Welcome to
                      AUTOSTAR
                      Press 0 to Align
                      or MODE for Menu
I Press 0       Initializing….
                     Smart Drive
                     LX200 GPS
                     © 2001 Meade
                     LX850 SL
                     Version 1.19
                     Welcome to
                     AUTOSTAR
                     Press 0 to Align
                     or MODE for Menu
I Press MODE      Initializing….
                             Smart Drive
                            (Blank screen for 2 seconds)
                            LX200 GPS
                           © 2001 Meade
                            LX850 SL
                            Version 1.19
                            Welcome to
                            AUTOSTAR
                            Press 0 to Align
                            or MODE for Menu
One additional comment...once this loop has run its course I can press the speed key and select a speed. When I do that, it goes right back in to the loop.
So here are my questions:
(1) Can I reinitialize the system from this situation?
(2) Should I be looking for a fault in the Autostar II hand controller or in the mount itself?
#54 carolinaskies
carolinaskies
Posted 31 December 2019 - 07:08 PM
The LX850 uses the Autostar II hand control, if you can find someone local to you and borrow one of those you can test to see if a different hand control results in the same results or corrects the action.
Since you are getting a loop I don't think you'll be able to reinit the system through the original hand control though you might be able to do it with a borrowed control.  You could attempt a reinstall of firmware by hooking up a laptop and downloading the Meade updater if you don't already have it.
