Caught an issue after 26 hours or 28 268 images. A ZWO: getexpstatus EXP_FAILED , after which PHD2 retried it 3 times then gave up and reconnected to the camera (and did not enable cooling) but continued making images.
Here's the log if anyone's interested in that :
01:48:08.401 00.000 140737072191232 worker thread servicing REQUEST_EXPOSE 1000 01:48:08.401 00.000 140737072191232 Handling exposure in thread, d=1000 o=3 r=(0,0,0,0) 01:48:09.702 01.301 140737072191232 ZWO: getexpstatus EXP_FAILED, retry exposure 01:48:11.004 01.302 140737072191232 ZWO: getexpstatus EXP_FAILED, retry exposure 01:48:12.305 01.301 140737072191232 ZWO: getexpstatus EXP_FAILED, giving up 01:48:12.323 00.018 140737072191232 worker thread setting skip send exposure complete 01:48:12.323 00.000 140737072191232 worker thread queueing reconnect event to GUI thread 01:48:12.323 00.000 140737072191232 Error thrown from /home/hans/src/phd2/worker_thread.cpp:157->Capture failed 01:48:12.323 00.000 140737353747008 Alert: Lost connection to camera PHD will make several attempts to re-connect the camera. 01:48:12.323 00.000 140737072191232 worker thread skipping SendWorkerThreadExposeComplete 01:48:12.323 00.000 140737072191232 worker thread done servicing request 01:48:12.331 00.008 140737353747008 Try camera reconnect, now = 1568936892 01:48:12.331 00.000 140737353747008 gear_dialog: ReconnectCamera 01:48:12.331 00.000 140737353747008 gear_dialog: DoConnectCamera [ZWO ASI Camera] 01:48:12.331 00.000 140737353747008 Status Line: Connecting to Camera ... 01:48:12.515 00.184 140737353747008 GetString("/profile/4/cam_hash/fb6ac968ce0ca5aa/whichCamera", "") returns "" 01:48:12.515 00.000 140737353747008 Connecting to camera [ZWO ASI Camera] id = [] 01:48:12.516 00.001 140737353747008 ZWO: find camera id: [], ncams = 1 01:48:13.193 00.677 140737353747008 ZWO: using mode BPP = 8 01:48:13.194 00.001 140737353747008 ZWO: usb3 = 1, is_mini = 0, name = [ZWO ASI1600MM-Cool] 01:48:13.194 00.000 140737353747008 ZWO: selecting snap mode 01:48:13.194 00.000 140737353747008 ZWO: IsColorCam = 0 01:48:13.194 00.000 140737353747008 ZWO: supported bin 0 = 1 01:48:13.194 00.000 140737353747008 ZWO: supported bin 1 = 2 01:48:13.194 00.000 140737353747008 ZWO: supported bin 2 = 3 01:48:13.194 00.000 140737353747008 ZWO: supported bin 3 = 4 01:48:13.389 00.195 140737353747008 ZWO: camera has cooler 01:48:13.389 00.000 140737353747008 ZWO: gain range = 0 .. 600 01:48:13.390 00.001 140737353747008 ZWO: lowest RN gain = 300 (50%) 01:48:13.390 00.000 140737353747008 ZWO: frame (0,0)+(4656,3520) 01:48:13.424 00.034 140737353747008 Connected Camera: ZWO ASI1600MM-Cool 01:48:13.424 00.000 140737353747008 FullSize=(4656,3520) 01:48:13.424 00.000 140737353747008 PixelSize=3.80 01:48:13.424 00.000 140737353747008 BitsPerPixel=8 01:48:13.424 00.000 140737353747008 HasGainControl=1 01:48:13.424 00.000 140737353747008 GuideCameraGain=50 01:48:13.424 00.000 140737353747008 HasShutter=0 01:48:13.425 00.001 140737353747008 HasSubFrames=1 01:48:13.425 00.000 140737353747008 ST4HasGuideOutput=1 01:48:13.425 00.000 140737353747008 GetBoolean("/profile/4/camera/AutoLoadDefectMap", 1) returns 1 01:48:13.425 00.000 140737353747008 auto-loading defect map 01:48:13.425 00.000 140737353747008 Loading defect map file /home/hans/.phd2/darks_defects/PHD2_defect_map_4.txt 01:48:13.425 00.000 140737353747008 Defect map file not found: /home/hans/.phd2/darks_defects/PHD2_defect_map_4.txt 01:48:13.425 00.000 140737353747008 Status Line: Defect map not loaded 01:48:13.426 00.001 140737353747008 GetBoolean("/profile/4/camera/AutoLoadDarks", 1) returns 1 01:48:13.426 00.000 140737353747008 Auto-loading dark library 01:48:13.426 00.000 140737353747008 Error thrown from /home/hans/src/phd2/myframe.cpp:2313->File does not exist 01:48:13.426 00.000 140737353747008 failed to load dark frames from /home/hans/.phd2/darks_defects/PHD2_dark_lib_4.fit 01:48:13.426 00.000 140737353747008 Status Line: Darks not loaded 01:48:13.427 00.001 140737353747008 Status Line: Camera Connected 01:48:13.430 00.003 140737353747008 Camera Re-connect succeeded, resume exposures 01:48:13.430 00.000 140737353747008 ScheduleExposure(1000,3,0) exposurePending=0 01:48:13.430 00.000 140737353747008 Enqueuing Expose request 01:48:13.431 00.001 140737072191232 Worker thread wakes up 01:48:13.431 00.000 140737072191232 worker thread servicing REQUEST_EXPOSE 1000 01:48:13.431 00.000 140737072191232 Handling exposure in thread, d=1000 o=3 r=(0,0,0,0) 01:48:13.431 00.000 140737072191232 ZWO: set CONTROL_EXPOSURE 1000000 01:48:15.700 02.269 140737072191232 Exposure complete
-- Hans
