ioptron Ipolar Aligned Perfect then what?
mount equipment astrophotography EAA
3 replies to this topic
#1 Michaeljhogan
Michaeljhogan
Posted 25 August 2019 - 11:37 AM
I aligned it very easy last night was a bit cloudy then cleared up do i do a one star alignment or two star after it
i set find zero position first always UTC was set to +60 date time everything i have a baader polaris illuminated
recticle to make sure one or two star alignment is pinpoint.
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 25 August 2019 - 12:22 PM
Yes, after doing polar alignment, goto zero position, then do a star alignment.
A one-star alignment will work for most viewing.  A two-star alignment will better model any remaining polar alignment error in your mount.  A 3-star alignment will also correct for cone error and give you the best results all across the sky.
#3 F.Meiresonne
F.Meiresonne
  • Loc: Eeklo,Belgium
Posted 26 August 2019 - 06:43 AM
Does the Zero position not to be set after every polar alignment? Unless the mount is permanently set up?
I am testing this out now.
On two occasions I worked it this way
Polar align - be sure Polaris is in the eyepiece - set zero position -(put mount off/onn still testing this) and do a one or two start alignment.
I both cases then I had no trouble with the goto afterwards
I found also that after getting Polaris in the eyepiece and setting to zero position my alignment stars fell into the eyepiece ...
#4 Michaeljhogan
Michaeljhogan
Posted 26 August 2019 - 09:39 AM
hello mine is permanently set up on pier
Also tagged with one or more of these keywords: mount, equipment, astrophotography, EAA
