Nexstar 114GT Model# 22098 and using a SkyQ Link Wifi 93959
9 replies to this topic
#1 SwampDawg
SwampDawg
  • Loc: St. Petersburg, Florida
Posted 09 September 2019 - 11:19 AM
Hello, I'm a new member of the site as well as a newb telescope user, from Florida.
I recently purchased a Celestron Nexstar 114GT model # 22098.
It was missing some parts and had no manuals but seems to function fine (from what I can tell). I've located some of the parts and it appears I've located most of the manuals thanks to https://www.nexstarsite.com .
I'm interested in using SkySafari with this telescope and obviously I would need a WiFi adapter.
That being said, does anyone know what WiFi adaptor would work with my telescope?
I'm looking at the SkyQ Link Wifi Adapter model # 93959/93973, but I cannot seem to find out if its compatible with my model.
Any help would be greatly appreciated!
Mark
#2 junomike
junomike
  • Loc: Ontario
Posted 09 September 2019 - 12:43 PM
Scroll down  on this link (to compatibility). It looks like any GT post 2015 is compatible with an Aux splitter.
#3 SwampDawg
SwampDawg
Posted 09 September 2019 - 01:08 PM
Well, there in lies my problem.
I don’t know the manufacturing date of my unit, but thinking it’s pre-2015.
All I have is the model # 22098, but no way to determine manufacturing date.
#4 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 09 September 2019 - 02:45 PM
One thing that might help is running the Version command (under the Utilities menu) and posting the firmware levels here.
You should see something like NXS4.xx or NXS5.xx (this is the firmware in the hand controller) and then a pair of other numbers (these are the motor controllers).
#5 Michael_Swanson
Michael_Swanson
    Author of The NexStar Users Guide
Posted 10 September 2019 - 12:01 AM
Mark has it right, the best way forward is to determine the version number of the hand control.  If you don't find a version command on the hand control menu OR if the version reported is 4.03 or 4.04, then it is definitely pre-2012 and it is NOT compatible with the SkyPortal/SkyQ Link adapters. (mid-2012 is the actual date the GT mount transitioned to the NexStar 4/5 SE electronics and became compatible with Celestron's WiFi adapters)
Best regards,
Mike Swanson
Author of "The NexStar Users Guide II"
Author of "The NexStar Users Guide"
Author of "NexStar Observer List"
#6 SwampDawg
SwampDawg
Posted 10 September 2019 - 08:01 AM
Thank you all, I'll see what I can find per version number.
Forgive my ignorance, but I have two additional questions:
1) Doesn't the Wifi module "replace" the hand controller?
2) If it does "replace" to hand controller, then doesn't the scope mount/motor determine if the module will work, rather than what version the hand controller is?
Edited by SwampDawg, 10 September 2019 - 06:12 PM.
#7 SwampDawg
SwampDawg
Posted 10 September 2019 - 08:54 AM
Retrieved the version number:
#8 Michael_Swanson
Michael_Swanson
Posted 10 September 2019 - 07:06 PM
1) Yes it does.
2) Older GT mounts had no way to display the MC (mount) firmware version so I was just simplifying the request to you as we would be able to determine the general MC generation based on the hand control version.
And...you have the post-2012 mount that is compatible with the Celestron WiFi module.
Best regards,
Mike Swanson
#9 SwampDawg
SwampDawg
Posted 11 September 2019 - 05:44 AM
Thanks very much for everyone’s help!
#10 MitchK
MitchK
  • Loc: Burbank, WA / Goldendale, WA
Posted 02 February 2020 - 01:08 PM
Hi all. I know this is an older post but I have something to add. I have three Nexstar mounts. A pre 2012 GT, a later (~2014) GT and an SLT.
I have been able to successfully connect to the SLT via WIFI using CPWI, SkyPortal, and SkySafari 6 Prowith little trouble other than disconnects using Skyportal and SkySafari. CPWI is rock solid on the SLT mount. I know the early GT is pretty much a lost cause. However, the later GT which has a Nexstar+ hand control (5.31.9200) and MC board firmware 5.21 will not work with CPWI. I can connect to the WIFI module, but it will not connect to the MC board. I am using the same Celestron WIFI module to test all three mounts. I can connect to the WIFI module when plugged into all three mounts. But that is as far as I can get with the later GT mount and CPWI. Now I can connect and control the later GT mount using SkyPortal and SkySafari. I still get the ever present WIFI disconnects, but it does at least work.
My preference is to use Stellarium on top of CPWI for WIFI control from a laptop. For me its easier to use and has a much larger display. Fortunately, my laptop also has a back lighted keyboard for low light use.
So the statement that the Celestron SkyPortal WIFI module is compatible with the later GT mount is correct. Its just that I have not been able to get CPWI to work with the later GT mount.
Any ideas?
