New - comparison of two telescopes
15 replies to this topic
#1 present
present
Posted 10 September 2019 - 07:50 AM
I'm new to this forum and overall new to this field - indeed thrilled to get started.
I wanted your opinion about two telescopes that are my (currently) final choices - either the Skywatcher Heritage 130P or the Bresser 130 DOB (couldn't find much information regarding this one).
I'm leaning towards the Heritage due to its positive reviews and cheaper price, though it's quite a challenge to find this one where I live (Israel) and ordering it online will cost more than the Bresser.
Is there much difference between the two?
Thank you in advance.
#2 SteveG
SteveG
  • Loc: Seattle, WA
Posted 10 September 2019 - 12:19 PM
They are likely equipped with the same optics. Your choice would depend on your portability needs. The collapsing tube Heratige is the same as the AWB OneSky, and the Bresser is the same as the Z130. If you don’t need the extreme portability, the the solid tube Bresser is your choice, with its rack and pinion focuser and tube rings.
  • vtornado and mrsjeff like this
#3 alexantos
alexantos
  • Loc: Estoril, PT (White Zone)
Posted 10 September 2019 - 04:55 PM
Check out this sale item on the Bresser shop. It's a 6" tabletop Newtonian with 89€ discount.
The only issue is the 50€ Shipping cost. Nevertheless you save 39€...
I have a similar 8" tube on a Dobson mount, and I can tell you that the optics are exceptional and the focuser is very precise. Also the red dot finder is very practical and easy to use.
Early this year I've posted a topic seeking advice, like you, to buy a scope. I also started asking about tabletop Newtonians but ended buying a Dobsonian. Check out the topic and maybe you'll find something useful for you in there.
Take care.
  • Cames and mrsjeff like this
#4 vtornado
vtornado
  • Loc: Northern Illinois
Posted 10 September 2019 - 08:09 PM
I second what Steve said, I have the bushnell aries 5 which is the same as the heritage.
The heritage collapses which is nice, but the Z130 has a R&P focuser and rings which will allow you to rotate the focuser to a position you like,
and it could help with balancing too. it also has a vixen finder shoe so you could ad an optical finder if you would like.
I have noticed my aries 5 changes collimation each time I use it, because of the trusses.  Not a problem a 30 second tweak with
a cheap laser an a barlow fixes it.  The solid tube will hold collimation better.
Edited by vtornado, 10 September 2019 - 08:09 PM.
  • SteveG likes this
#5 present
present
Posted 11 September 2019 - 08:02 AM
Thank you all for the information.
By the way, is a dobsonian scope significantly better than the table scope?
#6 SeaBee1
SeaBee1
  • Loc: Under the DFW light barrier
Posted 11 September 2019 - 08:13 AM
The Dob mounted scope is an all in one setup. Scope, mount, done. Very stable. A table top scope, on the other hand, requires you to put the scope/mount on something... like a table! And you need a very stable table to make it work well. The Dobs referred to by others also offer a bit more aperture as well.
The advantage of the table top scope is portability... until you figure in the table...
So, yes, the Dob mounted scope will be better in the long run.
Good hunting!
CB
#7 present
present
Posted 11 September 2019 - 08:45 AM
Thanks for the explanation.
Edited by present, 11 September 2019 - 08:46 AM.
#8 vtornado
vtornado
Posted 11 September 2019 - 02:51 PM
The "table" for a Z130 does not have to be that sturdy, it is a light scope, and it is small aperture,
so I don't normally exceed 150x.
I use a 6 gallon paint bucket on a lawn, I can track easy, better than a refractor on an alt-az mount
Of course if the ground you are on is highly sloped, or really bumpy a bucket wont work, you will have to use a 3
legged stand.
Some other ideas are a plastic milk crate,  plastic picnic coffee table, I have heard some use the hood of their car.
A wood picnic table like in a park will work, except if it has attached benches you can't sit on the same table.
Sometimes I sit on the ground with the scope on a blanket,  I have a grass allergy,
so I don't like to touch grass, you may not even need the blanket.
That being said there are some tables that don't work.  I have a small iron patio table that sways and vibrates.
A "table top"  and a dobsonian are both dobsonians.  What makes a dobsonion a dobsoian is
it is reflector telescope, and the mount is a box that sits on the ground.  As opposed to a tripod.
The difference between the table tob and regular is that a regular dob has a long focal length so when the
telescope is set on the ground the eyepiece is at a height that is comfortable for most adults to view.
Table tops are short focal length scopes where the eyepiece is too low to set the scope on the ground and view.
(unless you are sitting on the ground).
Edited by vtornado, 11 September 2019 - 08:15 PM.
#9 Tony Flanders
Tony Flanders
  • Loc: Cambridge, MA, USA
Posted 12 September 2019 - 05:01 AM
This is really all about aperture. Arguably, a tabletop scope like the Heritage or Bresser 130 is a Dobsonian. The only difference is that with a traditional Dob, the tube is supported on both sides, whereas with a one-arm mount it's only supported on one side. From a pure engineering viewpoint, it's better to support the tube on both sides, so that everything remains in balance. With a one-arm mount, by contrast, the tube tends to bend the single arm over toward the telescope. But if the tube is small and light enough -- as with a 130-mm f/5 scope -- then this bending torque is small enough not to be a problem.
So single-arm supports work OK up to about 5 or 6 inches of aperture; beyond that it's definitely better to use a traditional Dobsonian box support.
The other issue is whether the base is placed directly on the ground or on some kind of support. This depends on the length of the tube, the length of your own body, and above all, whether you observe from a sitting or standing position.
People tend to place the smaller one-arm scopes on supports and the bigger Dobs directly on the ground, but there are plenty of exceptions in both directions. I have in fact used the AWB OneSky (a.k.a. Heritage 130P) with the base placed directly on the ground. It works quite well as long as you yourself sit directly on the ground. Conversely, the small minority who strongly prefer observing from a standing position often place traditional 8-inch f/6 Dobs on some kind of support. Otherwise, you end up doing a lot of crouching or kneeling, especially if you're tall.
But when all is said and done, your question really comes down to "are 8-inch scope better than 5-inch scopes," since for all practical purposes all 5-inchers are on one-arm supports, and all 8-inchers are on traditional Dobsonian two-sided box supports. And the answer to that question is easy.
Ignoring issues of portability (definitely) and ergonomics and low-power capability (maybe), 8-inch scopes are better than 5-inch scopes. Much better. That extra 3 inches moves you from being able to discern features on Jupiter with considerable effort to having them in your face and obvious. It moves you from being able to resolve individual stars in a handful of globular clusters under dark skies to being able to resolve individual stars in many globular clusters even under mediocre skies. And it moves you into the realm where you can see spiral arms within a fair number of galaxies if you are lucky enough to have genuinely dark skies.
As for portability, I own both a 130-mm f/5 on a fairly sturdy home-built table and a 7-inch f/5.4 Dob that always sits on the ground when I observe. Both scopes superb ergonomics, though the 130-mm is a tad better.
The 130-mm f5 plus its table are much easier to carry than the 7-incher with no table. And much easier to place in a car, since I designed the table so that the scope nests inside it when the table is upside-down.
  • SeaBee1 likes this
#10 present
present
Posted 13 September 2019 - 06:55 AM
Valuable information from everyone. Much appreciated, thank you.
#11 aeajr
aeajr
  • Loc: Long Island, New York, USA
Posted 14 September 2019 - 11:26 AM
Dobsonian refers to the mount.
The tabletop scopes you asked about are on Dobsonian type mounts.  The optical tube assemblies on both are Newtonian reflectors.
Generally when you read Dob on this forum it is referring to a floor mounted AltAz mount that was designed by John Dobson.  It has become an industry standard mount.  But, as  you saw, there are tabletop versions too.
Most, but not all, Dobs have a Newtonian reflector optical tube assembly on them.   So the floor mounted Dobs differ from the table mounted Dobs you asked about by aperture and focal length.   The floor mounted units have a longer focal length and usually, but not always, larger aperture.
Different types of Telescopes
https://telescopicwa...-of-telescopes/
#12 present
present
Posted 15 September 2019 - 01:16 PM
Thank you for the information.
I'm thinking about getting the Sky-Watcher 8" Collapsible Dobsonian instead for its price and availability in my country. I have read tons of reviews about it, yet couldn't confidently decide if I should click the purchase button.
What's your opinion about it?
  • aeajr likes this
#13 SteveG
SteveG
  • Loc: Seattle, WA
Posted 15 September 2019 - 03:56 PM
All accounts I’ve read is that it is an excellent scope. This is a much better option than the table-top dob’s.
#14 present
present
Posted 21 September 2019 - 08:59 AM
Thank you very much.
Do you have any recommendation about collimation tools / necessary accessories?
  • aeajr likes this
#15 aeajr
aeajr
Posted 21 September 2019 - 10:40 AM
I read very good reviews of these.  However, note that these are not designed to come apart like truss dobs.  I had looked at these at one time.  Spoke with the Sky-Watcher people in their booth at the NEAT conference.
The top slides down the poles but does not come off.   A Truss Dob is designed to come apart so you can break it down into smaller pieces.
Both designs are good.  Just didn't want you to get the collapsable and be surprised that the top section doesn't come off.
This article covers accessories and suggestions.
https://telescopicwa...ls-accessories/
There is a wide range of collimation tools.  I have, and have used, collimation cap, combination tool, laser. They all work.
I currently use a laser to do the collimation and then check it with a collimation cap.   Then, before the start of every observing session I do a defocused star test to confirm.
If you collimation is off a little the scope still works.  You just might not get the absolute best performance out of it.   If it is way off, the performance is quite poor.
Edited by aeajr, 21 September 2019 - 10:41 AM.
#16 Binojunky
Binojunky
Posted 21 September 2019 - 11:18 AM
Having owned most of the popular 130 mm table top dobs over the years this is my experience with them, the Heritage 130 , its compact but hindered by a fixed focuser position, a crude helical focuser and being open tubed its prone to picking up light from other sources such as local street lamps, Compared with my Lightbridge 130 I found I liked the Lightbridge more. solid tube and a R&P focuser.
The Bresser if as pointed out is the same scope as the Zhumell Z130 ? is the better choice, rings make a huge difference in balance and focuser position, however its heavy compared to the H130 and has a plate covering the collimation screws on the main mirror, you need a  phillips screwdriver and a couple of allen keys not supplied. All are Synta products so optical performance should be the same allowing for unit to unit variations
 If you can handle a scope a bit bigger but easy to use the Orion XT6 is recommended?, no mucking about with a stool or table to mount in on, D.
Edited by Binojunky, 21 September 2019 - 11:22 AM.
