Wide field eyepiece for Vixen VMC 200L
8 replies to this topic
#1 Simply Peter
Simply Peter
  • Loc: Santa Fe, NM
Posted 11 September 2019 - 08:37 AM
I am contemplating the purchase of a Vixen VMC 200L.  I have a Meade 40mm HD-60 eyepiece which should give me 49x with a field of view of .82 degrees.  I am looking for suggestions for an eyepiece that will provide a wider field of view.
#2 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 11 September 2019 - 01:18 PM
Focal length is 1950mm.
Maximum field of view with 1.25" eyepieces = 0.80° with 27.2mm field stop
[TF = eyepiece field stop/telescope focal length x 57.296]
Maximum field of view with 2" eyepieces = 1.37° with a 46.5mm field stop
The HD-60 eyepiece doesn't come in a 40mm size.
The older Series 5000 Super Plossls in the 1990s came in a 2" 40mm with about a 38mm field stop.
The newer Series 4000 Super Plossl comes in a 1.25" 40mm with a 27.0mm field stop.
So it looks like you are going to convert to a 2" star diagonal and a 2" wide angle eyepiece to get a wider true field at 40mm.
The scope is 2" capable.
There are many choices for that eyepiece.  See the Eyepiece Buyer's Guide, pinned at the top of the Eyepieces Forum.
#3 Simply Peter
Simply Peter
  • Loc: Santa Fe, NM
Posted 11 September 2019 - 01:55 PM
I have had the Series 5000 5 element plossl that has a 60 degree field of view.  I assumed it was a HD-60.  I believe that I bought it in 2011 perhaps it was old stock?
#4 SeattleScott
SeattleScott
Posted 11 September 2019 - 02:15 PM
I bought the 26mm series 5000 around 2005.
#5 Starman1
Starman1
  • Loc: Los Angeles
Posted 11 September 2019 - 02:50 PM
Yes, it was old stock.  That's a 2" if I recall.
True field in that scope around 1.12°
You can't get a lot wider, but a 68° 40mm widefield would allow you to maximize the field in that scope.
#6 SeattleScott
SeattleScott
Posted 11 September 2019 - 03:51 PM
38mm 70 degrees is a popular budget option. Vixen 42 LVW is higher end and relatively light. ES 40/68 is a good performer, just heavy. 41 Panoptic might be the best option right now, but naturally rather expensive, and heavy. They recently had a clearance sale on the 40mm Maxvision
#7 Simply Peter
Simply Peter
  • Loc: Santa Fe, NM
Posted 15 September 2019 - 03:00 PM
The deal on the VMC I was looking at fell through so I ended up buying a Vixen VC 200L with a focal length of 1800mm.  The Panoptic eyepieces are out of my price range. I currently have a 31mm Baader Aspheric 72 degree FOV and the Meade 40mm 60 degree FOV plossl.  I am wondering about adding something in the 50+mm range I know Meade makes a 55mm and Tele Vue makes a 56mm. I'm wondering about peoples opinion on these and whether there are other options.
#8 Starman1
Starman1
  • Loc: Los Angeles
Posted 15 September 2019 - 04:41 PM
If you can afford the TeleVue, it is excellent in that focal length.
TV makes the 55mm and Meade makes the 56mm--you had it reversed.
Look for used ones, and you can save a bundle.
The VC-200L is a very different beast.
Specs:
Optical Design: VISAC Aspherical Mirror Reflector
Aperture: 200mm
Focal Length: 1800mm
Focal Ratio: f/9.0
Back Focus (from rear edge of focuser body): 149.0mm for optimum control of spherical aberration and adherence to the focal length.
Back Focus with Reducer (from rear edge of reducer): 63.5mm
Coating: Multi Coated (lens), Enhanced (mirrors)
Resolving Power ;.56 arc sec
Limiting Magnitude: 15.6 at a pristine site
Light Gathering Power: over 1000x the eye.
Adapter Thread: 60mm/50.8mm
Astrophotography: Prime Focus, Eyepiece Projection & Afocal Imaging
Visual Back: Compression Ring,
Tube Length: 23.6" (600mm)
Optical Tube Diameter: 9.1" (232mm)
Optical Tube Weight: 13.2 lb
Accessories; Dove Tail Mounting Rail; Carry Handle; Flip Mirror Diagonal;
** the flip mirror diagonal has a 49mm thread on the front.  To use 2" filters, get a 49mm male to 48mm female ring from a camera store to reduce the thread size for 2" filters.
This scope has a flat field, unlike the VMC-200, so It was a good choice.
#9 Simply Peter
Simply Peter
  • Loc: Santa Fe, NM
Posted 17 September 2019 - 07:58 AM
Don,
Thanks for the information, I am looking forward to receiving the scope and seeing what it reveals that my 120mm Apo was unable to.
