Need help w/Teflon Sizes & PTFE vs. UHMW
10 replies to this topic
#1 skysoldier173abn
skysoldier173abn
Posted 11 September 2019 - 10:51 AM
Trying to take the slop out of plastic Orion Focusser for XT6 and Also needs appropriate size for 4.5” Dob Alt-Az Bearings. Home Depot and Ace looked at me funny when I asked for strips or sheets of Teflon then directed me all over on a search for nothing 😀
Amazon markets different sizes of Teflon or UHMW. Which material should I use? At what thickness for the Alt/Az bearings for 4.5” Dob base?
what size for focusser drawtube? I guess I could disassemble the focusser and measure the strip with calipers or the gap. Honestly I don’t want to fudge the numbers up and order the wrong stuff. Any help or info is appreciated.
#2 GDAstrola
GDAstrola
  • Loc: St. Louis
Posted 11 September 2019 - 11:25 AM
When you are ready to buy take a look at the following for Teflon/PTFE and UHMW products.
https://www.mcmaster...ethylene-sheets
  • skysoldier173abn likes this
#3 skysoldier173abn
skysoldier173abn
Posted 11 September 2019 - 04:58 PM
Thanks for the link. I’m trying to find info to suit my needs. I’ll keep digging. If anybody knows of a post to read or a link to follow I would surely appreciate the help.
#4 Jon Isaacs
Posted 11 September 2019 - 11:49 PM
For the focuser I use 0 015" Teflon that's etched on one side so it's bondable.
#5 skysoldier173abn
skysoldier173abn
Posted 12 September 2019 - 07:49 AM
Beautiful Jon! Thanks for the tip .
#6 Jon Isaacs
Posted 12 September 2019 - 08:30 AM
PM Sent
#7 skysoldier173abn
skysoldier173abn
Posted 12 September 2019 - 11:48 AM
Found the dimensions for Alt-Az bearings for Dob Mount.
Stellafane.org has the resources you need to construct a Dobsonian Mount simply and effectively.
#8 skysoldier173abn
skysoldier173abn
Posted 14 September 2019 - 09:46 PM
Slop is taken care of! Shimmed with Teflon strips. Thanks Jon!
#9 tag1260
tag1260
  • Loc: Ohio, USA
Posted 06 October 2019 - 06:17 PM
Where do you find the etched teflon strips?
#10 skysoldier173abn
skysoldier173abn
Posted 07 October 2019 - 08:45 AM
It was remnants of a sheet I cut strips out of. My best guess is McMasters. IIRC the size was 0.15” sheet with discolored back for gluing. However I used Scotch double sided tape and it works quite well.
#11 skysoldier173abn
skysoldier173abn
Posted 07 October 2019 - 08:46 AM
0.015” sorry!
