Registax 6 wavelet schemes files missing locally but visible in program?
8 replies to this topic
#1 markm75c
markm75c
  • Loc: Pittsburgh, PA
Posted 11 September 2019 - 12:34 PM
I have registax 6 on two machines. I'm trying to figure out how to get the saved schemes from the one machine to the other.
On the original if you do a load scheme you can see all the files and the paths show the program files (x86) registax location, but they dont exist when viewed in explorer.
I checked user profile and programdata and cant find references to where these would actually be (guessing internal?)
Does anyone know how to export these to use on another machine then import?
Thanks in advance
#2 einarin
einarin
Posted 11 September 2019 - 12:50 PM
Have you searched for *.rwv files ?
#3 markm75c
markm75c
Posted 11 September 2019 - 12:58 PM
I had done this, just finally found some, ok that was the solution and i wouldnt have thought to look here, but in case anyone else runs into it, at least on win 10 v1903 they are here:
\AppData\Local\VirtualStore\Program Files (x86)\RegiStax 6
#4 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 11 September 2019 - 03:23 PM
Ah thats useful. I had been mystified about this myself.
#5 DMach
DMach
  • Loc: The most light-polluted country in the world :(
Posted 11 September 2019 - 09:51 PM
Glad you found them!
I had the exact same challenge when I changed laptops recently ... certainly not the most intuitive of file locations.
#6 Tulloch
Tulloch
  • Loc: Melbourne, Australia
Posted 11 September 2019 - 10:05 PM
They are just stored in the same folder where you installed the Registax executable - where else would you expect them to be?
Andrew
#7 happylimpet
happylimpet
Posted 12 September 2019 - 08:14 AM
Andrew
When you save them, you navigate to a folder - but they arent actually stored there. When you open registax again, they appear to be there - but theyre not. At least not from explorer. Its all a bit weird.
#8 Tulloch
Tulloch
Posted 12 September 2019 - 08:28 AM
Umm, OK.
I think your path "\AppData\Local\VirtualStore\Program Files (x86)\RegiStax 6" is just a pointer to the
"C:\Program Files (x86)\RegiStax 6" folder, which is where you installed Registax in the first place. Are you sure they are not there?
Andrew
#9 happylimpet
happylimpet
Posted 12 September 2019 - 10:05 AM
Umm, OK.
Andrew
Im sure youre right. Its just very odd that theyre not where you tell registax to put them, and where registax pretends to find them again. Useful to know where they actually are!
Having said that, this is all from memory......
Edited by happylimpet, 12 September 2019 - 10:06 AM.
