Celestron Ascom not connecting
5 replies to this topic
#1 ippiu
ippiu
  • Loc: Italy
Posted 11 September 2019 - 05:09 PM
Hi to all.
I cannot connect my CPC Celestron in sharpcap; while with CPWI and nexremote everything works.
With CPWI and nexremote no problem
But with Celestron ascom, CPWI or Poth nothing works
Any help?
#2 skaiser
skaiser
  • Loc: dallas Texas
Posted 11 September 2019 - 06:40 PM
I believe , if you are running CPWI, then you must connect through CPWI ascom, not celestron ascom.
i think celestron ascom only works if you are connected via the port on the bottom of the hand control
Edited by skaiser, 11 September 2019 - 06:41 PM.
#3 ippiu
ippiu
  • Loc: Italy
Posted 12 September 2019 - 02:20 AM
i connect the mount with pc via mini usb port on the bottom of the HC.
With CPWI or nexremote no problem. When i try to connect via ascom in Sharpcap nothing works...
#4 skaiser
skaiser
  • Loc: dallas Texas
Posted 12 September 2019 - 07:03 AM
Hi
 My mistake . You need to use the CPWI mount connection in the Sharpcap Settings Dropdown for Mounts.
Make sure you are using the latest version of CPWI from the Celestron web site.  Ver 2.2.3
Make sure your scope is being recognized in CPWI and you can control it OK.
Once connected to scope  in CPWI , then start Sharpcap and establish the connection with CPWI.
Here are some pictures of the connection:
sharpcap connect0
sharpcap connect1
Once the correct ASCOM is identified you can then connect in SHarpcap under scope controls
sharpcap connect2
Hope this helps.
Edited by skaiser, 12 September 2019 - 07:10 AM.
  • KPH and GalaxyPiper like this
#5 ippiu
ippiu
  • Loc: Italy
Posted 12 September 2019 - 10:32 AM
Yes, solved.
With CPWI:
- first open CPWI, click connect scope, and keep opened the program (in background)
- than open Sharpcap and use CPWI in the dropdown mount menĂ¹
With Celestron Ascom:
It works but i must disconnect everything and reconnect, expecially usb from PC, after switchong on the mount....
#6 skaiser
skaiser
  • Loc: dallas Texas
Posted 12 September 2019 - 11:41 AM
Great.
hope you get some clear weather for viewing.
had a lot of haze lately plus very hot nights .
hope I was some help
