Celestron c11 tube balance
8 replies to this topic
#1 m11
m11
  • Loc: Australia
Posted 11 September 2019 - 05:46 PM
Hi All,
I have a Celestron CPC 11 on the standard alt az dual fork mount in which a small amount of weight at the back will tip the tube backwards. Not sure if there is something I can do to tighten?
It doesn't take much as I can slightly touch the tube and it will go backwards. The tension knobs are tighten as much as I can as well.
Has anyone else had a similiar issue? I believe this is impacting tracking as well.
#2 zakry3323
zakry3323
  • Loc: Pittsburgh
Posted 11 September 2019 - 06:06 PM
Getting a good balance is key!
https://starizona.co...00-complete-kit
I've also seen folks do everything from taping on sandbags and magnetic weights to hanging various things off of the front of their OTA's :)
  • tomwall likes this
#3 m11
m11
  • Loc: Australia
Posted 11 September 2019 - 07:43 PM
Hi Zak,
Thanks for that - will look into that kit. Its frustrating especially when pointing near the meridian and scope just flips back. confused1.gif
Appreciate the response.
  • zakry3323 likes this
#4 zakry3323
zakry3323
  • Loc: Pittsburgh
Posted 11 September 2019 - 08:14 PM
Hi Zak,
My pleasure! It's especially handy if you like to swap out differently weighted eyepieces, or if you become interested in astrophotography and want to put a camera on the back of it.
Welcome to cloudy nights!
#5 yowser
yowser
Posted 12 September 2019 - 07:36 AM
I had a similar issue when I added a MoonLite focuser to my Vixen VMC260L.  Adding an Astrozap dew shield allowed me to balance it perfectly.
#6 tomwall
tomwall
  • Loc: Arizona, USA
Posted 12 September 2019 - 07:47 PM
Back in the day, I had a fork mounted C8. Every time I loosened  the clutches to swing to a different spot in the sky, my OTA  would swing skyward too. I had to make sure I was holding it. My workaround was to tie a small bag to the front end and place small rocks in it until it balanced. And yes, all my friends made fun of me. But, it worked! waytogo.gif
Tom,
Tucson
#7 m11
m11
  • Loc: Australia
Posted 13 September 2019 - 05:45 AM
 Hi Zak,
Thanks for the warm welcome :)
#8 m11
m11
  • Loc: Australia
Posted 13 September 2019 - 05:52 AM
Hi Yowser,
Will add that as well to try to balance out the front with my dew shield.
#9 m11
m11
  • Loc: Australia
Posted 13 September 2019 - 06:14 AM
Tom,
Tucson
Yah that is my problem as well. Good idea and its a novel one at that. Whatever works I say :)
Thanks for idea - I will look at adding weight to the front as Celestron have recommended the scope be serviced and sent in - not going to be a cheap exercise as the scope needs to be sent interstate.
Mel
