C14 forks mount disassembly
16 replies to this topic
#1 telfish
telfish
    3D Astro Solutions, custom 3D printing for Astrophotography
  • Loc: Adirondack Mountains NY
Posted 12 September 2019 - 11:10 AM
I have an old C14 fork mount I want to remove the byers drive from. I have removed the motor and worm part but for the life of me I cant see a way to remove the casing around the ring worm gear. Anyone ever taken these apart and can give me advice?
#2 scngc7317
scngc7317
  • Loc: Menifee California
Posted 12 September 2019 - 11:58 AM
if I remember you work down from the fork side, a bolt or nut in the center I think hmm.gif
#3 telfish
telfish
Posted 12 September 2019 - 12:00 PM
I got under the cover there. And I found a small contact plate then a silver piece with three setscrews which I undid. Can't find a way to get that silver piece off.
#4 dmcnally
dmcnally
    Vendor - Dave's Astro Shop
  • Loc: Lompoc, CA
Posted 12 September 2019 - 12:14 PM
Can you post some pictures?
Clear Skies,
Dave
#5 telfish
telfish
Posted 12 September 2019 - 02:45 PM
Pics
#6 gnabgib
gnabgib
  • Loc: Fall River MIlls Ca.
Posted 13 September 2019 - 09:53 AM
The "silver" piece is removed my unscrewing it counter-clockwise just like a bolt.  You first loosen the three setscrews then grab the silver piece with your fingers (or pliers) and unscrew it.  This is the retainer that holds the polar axis assembly in the polar axis housing.
I have worked on hundreds of these assemblies.  There are wires attached to the center contact assembly and you need to disconnect them inside underneath the worm wheel.
Kevin
#7 MitchAlsup
MitchAlsup
Posted 13 September 2019 - 09:55 AM
It would not surprise me if you had to disassemble it from the top.
#8 telfish
telfish
Posted 13 September 2019 - 11:10 AM
Thanks guys, managed to get it apart and this is what I am left with, apart from a load of scrap metal.
Is this assembly useful to someone wanting to make a goto dob? If so has it any value and is it a Byers made drive?
  • dmcnally likes this
#9 telfish
telfish
Pic2
#10 telfish
telfish
Posted 13 September 2019 - 11:11 AM
Pic3
Edited by telfish, 13 September 2019 - 11:11 AM.
#11 gordtulloch
gordtulloch
Posted 13 September 2019 - 11:28 AM
The motors are useless, I guess with the gear and worm you have a nice start on one axis but for a Dob a circular plywood disc with GT2 timing belt glued to it running against a GT2 gear gives you much the same thing... and you can easily make 2 of them!
#12 telfish
telfish
Posted 13 September 2019 - 11:41 AM
Thanks. I am guessing there is another smaller gear set in one of the arms.
#13 dmcnally
dmcnally
  • Loc: Lompoc, CA
Posted 13 September 2019 - 12:17 PM
Thank you for the pictures.  I used to have a C14 on a sandcast fork setup.  I never took it apart, but I'm sure someone else will find these pictures helpful.
Clear Skies,
Dave
#14 gnabgib
gnabgib
Posted 13 September 2019 - 12:19 PM
That is the stock Celestron made drive and not the Byers retrofit.  The ac motor is the drive motor and the dc motor would add very slow motion capability using a switch in the hand control.
Kevin
#15 gregj888
gregj888
  • Loc: Oregon
Posted 13 September 2019 - 04:13 PM
I hacked an old Meade 8" adding an OnStep (Arduino stepper) controller.
Same could be done here...
#16 telfish
telfish
Posted 13 September 2019 - 04:15 PM
It could, it's a bit of a beast though.
#17 telfish
telfish
Posted 13 September 2019 - 04:17 PM
OK so I have the thing in bits, if anyone wants anything at all from it let me know and you can have the parts free only pay mailing costs.  It's pretty much the complete system.
