usb-nSTEP STEPPER belt drive for camera/Redcat focusing ring -- yeah we do that
12 replies to this topic
#1 rigelsys
rigelsys
    Vendor (Rigel Systems)
Posted 12 September 2019 - 05:11 PM
Hi All,
Just completed a usb-nSTEP STEPPER setup using belt drive to turn the focusing ring for camera lenses, and scopes like the WO Redcat that uses a focusing ring.  Looking forward to feedback from the Redcat customer, but trying it out on my DSLR, it looks to do the trick!  I think its a good alternative to split gears, as one belt can fit various size focusing rings.  Tension is adjusted by sliding the STEPPER in/out on its cross bar.  I have my DSLR attached to a dovetail bar, and the stepper rides on a crossbar attached to the dovetail bar.
  • psandelle, premk19 and zakry3323 like this
#2 rigelsys
rigelsys
Posted 12 September 2019 - 06:43 PM
here's a photo of the stepper and cross bar on my well worn dovetail bar, to show how it comes together.
#3 Richoff  Happy Birthday!
Richoff
  • Loc: SW Ontario Canada
Posted 12 September 2019 - 07:01 PM
Cool, how many steps does it have
#4 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 12 September 2019 - 08:24 PM
It has n steps.
I couldn't resist.
Edited by guyroch, 12 September 2019 - 08:25 PM.
  • psandelle likes this
#5 rigelsys
rigelsys
Posted 13 September 2019 - 01:17 PM
It has n steps.
I couldn't resist.
stepper has 0.07 degree resolution (full steps) twice that in half stepping.  Given the gear ratio between the pulley gear and the focus ring, is about 3/1 that means about 0.02 degrees per full step!
  • Skywatchr likes this
#6 rigelsys
rigelsys
Posted 16 September 2019 - 05:57 PM
more photos of the WO Redcat install
#7 karambit27
karambit27
  • Loc: Rochester, NY
Posted 18 September 2019 - 05:17 PM
What's the cost? I don't see it anywhere on your site.
#8 rigelsys
rigelsys
Posted 18 September 2019 - 06:46 PM
hi the bracket and belt gear cost is the same as for all our other stepper kits.  We do over a hundred variants of focusers with gear coupling, this is our foray into belt coupling.  A usb-nSTEP basic + belt drive system (as above) is $351.80 plus shipping.
thank you for the inquiry :-)
#9 DMRandall
DMRandall
Posted 27 September 2019 - 01:52 PM
I had a nSTEP setup from another scope that I've been modifying to fit various scopes.  I don't recall the original focuser mount that this came from, but it was easily installed on my WO Redcat.  I used a modified version of deepskydad's GT2 belt ring - which has the advantage of minimizing belt slip because the teeth match the belt, and the ring clamps on tightly to the rubber focusing sleeve.  I tested this out in SGP auto focus with a step size of 50 and 7 autofocus step points.  Perfect V curve!  There may be a bit of backlash to pull out, I haven't finalized my auto focus settings yet, but I know my geared version on my Stellarvue needs 35 steps of backlash clearing.
Photos of the setup in my album:
RedCat 51 with nSTEP Stepper focuser
Album: WO Redcat 51
7 images
0 comments
Dave
#10 rigelsys
rigelsys
Posted 27 October 2019 - 09:24 PM
Dave
Thanks dave, glad to see it working!
#11 rigelsys
rigelsys
Posted 27 October 2019 - 09:37 PM
I've just got results back from a customer who's put it on his system.
"Got to try the belt driven focus on my Rokinon 135mm lens at f/2.8. Worked great! Attaching focus curves from Sequence Generator Pro (SGP). I used half stepping in Rigel software and in SGP: step size of 60, 9 point curve and 100 steps of backlash in 'IN' direction."
Example "V" curve below.  So consider the nSTEP Belt drive fully in production :-)  A usb-nSTEP basic + belt drive system is only $351.80 plus shipping.  Temp sensor included free with the full kit.
#12 premk19
premk19
Posted 28 October 2019 - 02:42 PM
Here's the actual Rokinon 135mm lens setup for the AF curve shown above: (setup shown in the post above is my Nikon 105mm f/2.5 lens which I haven't tested yet)
Last night I tried AF at f/2, and that worked great as well.
Can confirm waytogo.gif Over two nights I ran SGP AF routine about 10 times, and the lowest quality score I got was 97%
Edited by premk19, 29 October 2019 - 03:38 AM.
#13 rigelsys
rigelsys
Posted 26 January 2020 - 11:37 PM
now up on website along with split gear stepper focusing
http://rigelsys.com/...otorcamera.html
with sample images :-)
