Polemaster on a fork mount
6 replies to this topic
#1 Jeff Struve
Jeff Struve
  • Loc: Iowa, USA
Posted 13 September 2019 - 12:29 PM
Hi all...
I did a search for this topic and found 1 back in 2016... no replies at all!
Anywho, I am helping one of the local schools set up their new observatory... they have an LX600ACF on a wedge set up in their roll off building and want some help doing a polar align.
Anyone have any pics as to how they successfully fastened their Polemaster to this type of beastie?
Thanx!
Jeff
#2 Lola Bruce
Lola Bruce
  • Loc: Southern California
Posted 13 September 2019 - 03:53 PM
Mounted on a wedge a fork is an equatorial mount. As a result the normal polemaster procedure should prevail. My question is first this is a fixed installation? If yes why not do a drift alignment?
Bruce
#3 carolinaskies
carolinaskies
  • Loc: Greenville SC
Posted 13 September 2019 - 06:36 PM
If you look up the old Tuthill finder you'll see the Polemaster will need to be affixed orthagonally off-center like the Tuthill.
https://www.cloudyni...ope-on-a-wedge/
In the following thread they postulate mounting the polemaster centered on the dust cover(or make one to fit the polemaster)
http://www.astronomy...-telescope.html
#4 555aaa
555aaa
    Vendor (Xerxes Scientific)
  • Loc: Lynnwood, WA, USA
Posted 15 September 2019 - 04:29 PM
Just clamp it to a fork arm with a c clamp or woodworking clamp. It just has to point north and be rigidly clamped to the ra axis. It does not have to be on axis but it's optical axis should be parallel to the mechanical ra axis. I don't think it has to be perfect.
  • Don W and schmeah like this
#5 schmeah
schmeah
  • Loc: Morristown, NJ
Posted 20 September 2019 - 07:42 PM
it just needs to move with the RA axis. As long as it’s pointed North you can put it anywhere on the tube.
Derek
#6 charlesgeiger
charlesgeiger
Posted 21 September 2019 - 02:47 AM
Yes, but it has to be pointing directly north along with the optical axis of your scope.  You will have cone error or other complex errors if it is not perfectly aligned.  If it is off a bit, it will still probably be good for visual.
Charlie
#7 schmeah
schmeah
Posted 21 September 2019 - 05:00 AM
Charlie
Actually this is not true. It has been explained why many times on CN. See posts # 6, 12 and 16 in this thread. I have confirmed this with my own cheap 59 cent custom adapter. When it is slightly malaligned, it makes no difference.
Derek
Edited by schmeah, 21 September 2019 - 06:20 AM.
