Plastic Rod for encoder shaft
4 replies to this topic
#1 Muleskinner115
Muleskinner115
Posted 13 September 2019 - 10:07 PM
I am looking for some sort of material other than wood or metal that I can turn on a lathe.  Ideally, it should be 1.25 inches in diameter, 4 inches long, able to be turned on a lathe using wood tools and capable of being drilled and tapped.  Perhaps Delrin would work.  I have never worked with it before.  Any suggestions and sources of supply would be appreciated.
Tim
#2 Kunama
Kunama
    Aussie at large
  • Loc: Canberra, Australia
Posted 13 September 2019 - 10:23 PM
Tim
Acetal (Delrin) or UHMWPE (Ultra High Molecular Weight Polyethylene) will do the job, both can be drilled and tapped but you would need to use a very small lathe tool, especially for the acetal.... hasten slowly !!!
Can you find someone with a metal lathe???
Edited by Kunama, 13 September 2019 - 10:24 PM.
#3 steveastrouk
steveastrouk
  • Loc: State College, Pa.
Posted 14 September 2019 - 02:30 PM
Tim
Amazon is actually pretty useful these days for little pieces, but there's a company called www.plastiblocks.com who do some nice bundles of ABS rod
#4 Kiriakos_GR
Kiriakos_GR
  • Loc: Central, Greece
Posted 14 September 2019 - 04:21 PM
Any one using lathe for metal work he has also Acetal (Delrin) Rod for samples and testing.
Rods are sold in fixed length, you better ask for a favor (sample rod purchase) from a small factory or a shop producer of metal parts.
Woodwork lathe this is not accurate enough for fine work.
Edited by Kiriakos_GR, 14 September 2019 - 04:24 PM.
#5 Muleskinner115
Muleskinner115
Posted 14 September 2019 - 08:25 PM
Thanks everyone. I found a guy with a small metal lathe who will do the job just to be helpful. I will get him some delrin to turn.
Tim'
  • Kunama likes this
