QHY183M & Flats = Frustration
94 replies to this topic
#26 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 16 September 2019 - 01:14 PM
Wow! Looks great. What an improvement!! Was it just the pedestal that removed that last bit of ampglow?
-Jim
Edited by kingjamez, 16 September 2019 - 01:15 PM.
#27 terry59
terry59
  • Loc: Colorado, USA
Posted 16 September 2019 - 02:35 PM
-Jim
Thanks Jim...yeah that did the trick.  It took a few tries to get the right amount added. Do you use a pedestal?
#28 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 16 September 2019 - 04:01 PM
terry, I'm glad you figured it out.  But I'm also a bit confused.
With the ZWO version of this chip/camera, I don't need to add a pedestal to the darks.  But then I don't use bias, either...maybe that's the difference?
Did you try it without the bias, and with just darks?
Just trying to figure out what's going on...:)
#29 terry59
terry59
Posted 16 September 2019 - 04:45 PM
No, I haven't tried without bias....the effect of calibrating with them is very noticeable as is the difference in the master dark with and without the pedestal added. I suspect that it is from the bias since each is 0.00005 seconds long vs multiple seconds with flat darks.
Here is the master dark with no pedestal and the one with 100
#30 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 16 September 2019 - 05:32 PM
Good point. I wonder what the median ADU is of the bias. Wanna wager on it being around 100?
I don’t use a bias or a pedestal. While it’s great that you are able to get the +100 pedestal to get you to useable images, it seems like a bandaid covering a yet discovered underlying issue.
If it were me, I’d try not using a bias at all including during the creation of the master dark.
-Jim
#31 terry59
terry59
Posted 16 September 2019 - 06:01 PM
-Jim
Jim, I'm willing to try...it's how I learn best. Are you suggesting I create a master dark with no calibration first?
Here are a bias and the two master darks if you'd like to look at them.
https://1drv.ms/u/s!...C_yh52?e=uY26dk
#32 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 16 September 2019 - 07:00 PM
Those were very helpful, thank you.
One thing that stood out in looking at those files and the previous files is that the bias has a median of 1936 while your flat dark of 50 seconds has a median of 1904. This is not right. It means your bias is at a bare minimum 32 too high, probably more like 35-40 ADU high.
Looking at your bias-calibrated, non-pedestal added dark, it is clearly clipped which means your bias is over calibrating.
I'm certainly no expert, but I think this is clear evidence that you should not use a bias in any part of the calibration process. I would recreate your master darks without using a bias, and calibrate your flats with only a dark flat (again, no bias).
-Jim
  • jdupton likes this
#33 OldManSky
OldManSky
Posted 16 September 2019 - 07:14 PM
Jim, you beat me to it.  I was going to say the same thing.
I don't use bias frames with my ZWO version of the 183...and I don't have to offset the darks with a pedastal :)
  • kingjamez likes this
#34 View2
View2
  • Loc: Vancouver, WA USA
Posted 16 September 2019 - 07:35 PM
If I were having your trouble I would consider using dark Flats. You can use them instead of a bias. Here you take an equal number of darks at the same setting as your Flats. Don't get used to not using any Flats!
#35 View2
View2
Really nice image by the way
#36 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 16 September 2019 - 11:42 PM
I learned some things tonight.
I took a variety of bias frames. I used unity gain (111 for me) at -15c temperature.
Exposure Time:            Median ADU:      Offset:
0.000s (AFAP)              705.6                   10
0.20s                             706.08                 10
0.50s                             706.8                   10
15s                                706.56                 10
0.000s                          1985.4                  30
0.20s                            1986.0                  30
Now we know the source of the dramatic difference in ADU between Terry's frames and mine. It's simply offset. I didn't expect offset to have that much of a... well.... offset. I need to learn more about what exactly 10 and 30 mean... it's clearly not 10 and 30 ADU in 16 bit format.
The difference between them is 1279.8 which is awfully close to 30-10==20 and 20 * 64 == 1280. So it appears that the offset is multiplied by 64 in 16bit terms or 1x in 10 bit terms. I'm sure someone smarter than me will come along.
It's also interesting to note that the median ADU of my 15s dark is less than the 0.50s dark. Both were 100 frames so should be fairly accurate.
My camera is doing a long run of darks right now, but I also plan to add 15s and 0.5s at 30 offset to see if the same inversion happens. If it does, I'll go in small increments to map out where the median ADU shift / inversion happens.
It's also nice to see that I'm getting very similar numbers between my ASI and Terry's QHY camera. I also have a 183MC and a cursory look at it's calibration frames show very similar results to my 183MM... this is obviously expected but we test because we don't always get what we expect!
More investigation coming in as soon as I can take the data.
-Jim
Edited by kingjamez, 16 September 2019 - 11:55 PM.
#37 cuivienor
cuivienor
  • Loc: Tokyo, Japan
Posted 17 September 2019 - 01:16 AM
Is it just me, but I thought that Bias frames were simply not recommended for any of those CMOS cameras? Everything I've read from ZWO is a solid "Don't use bias frames" recommendation...
#38 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 17 September 2019 - 01:22 AM
What about what I'd heard about flats needing to be at least 2 seconds in length?
With my Spike-A-Flat at 50%, I use ranges from 0.01" for Lum to 1.2" for Sii. That brings the ADU to around 28000-31000 (for the ASI1600MM-C)
I do hope this will work, although I'm quite adaptable--but get cranky if I need to adapt too much smile.gif
Terry, I just ordered it, since you liked it despite your problems. Let's see how long free shipping takes smile.gif
I am not sure where you are getting 2 seconds...
The ASI1600/QHY163 needed flats at least 0.2 seconds (zero point two) in length to avoid a bias instability issue, but that is JUST the Panasonic M cameras...the guidelines for that do not apply to every CMOS camera...
The IMX183 is just fine with biases, so you  can calibrate your flat frames with biases if they are short enough.
#39 Jon Rista
Jon Rista
  • Loc: Colorado
The no bias frames/0.2 second min exposure should only apply to Panasonic M based CMOS cameras. It does not apply to every CMOS camera in existence...
#40 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 17 September 2019 - 01:25 AM
I've been struggling with flats until today when I decided to forego using them. What a huge difference. I once again have the issue with calibrating amp glow out but I had to use the dark flats and I think I need to shoot some regular bias frames now.
Here is the result...cropped to remove the amp glow area, lightly processed in PI and PS
Only three months in the making
GM-8/SV70T/QHY183M/Baader 3.5nm Ha filter
Image looks great! You are definitely getting good resolution for your setup.
Regarding flats...what exactly is the issue? Bias frames should be fine with the IMX183 if the flats are short. As with any camera, if the flats are longer then dark flats should be used...but there is no 2 second exposure limimtation, nor is there even a 0.2 second exposure limitation like the Panasonic M cameras. You should be able to use very short flats and biases if you prefer.
One thing you may run into is the rolling electronic shutter may interfere with the oscillation rate of a flat panel, and if it does, that might cause some problems. I have been using open (uncovered) aperture blue sky flats with my ASI183, with flat exposures of small fractions of a second along with bias calibration. So far things have been working nicely (save the occasional airplane in a flat frame. :p
#41 Stelios
Stelios
  • Loc: West Hills, CA
Posted 17 September 2019 - 02:29 AM
OK, what's "short" and what's "longer" ? I take flats depending on filter at exposures from 0.01" to 1.2". We'll stipulate that 0.01" is short, but is 1.2" "longer"?
Also I keep hearing this about bias, but I have an ASI1600MM-C, which is a Panasonic "M" camera, correct? I have been using a superbias (100 bias frames) taken at shortest possible exposure with SGP for *years* now, with no ill effects (following the Warren Keller approach in Inside Pixinsight). I am tempted to take some dark flats just to compare and see if there's any discernible difference, but it's not going to be major for sure.
#42 terry59
terry59
Posted 17 September 2019 - 06:54 AM
0.20s                             706.08                 10
0.50s                             706.8                   10
15s                                706.56                 10
0.000s                          1985.4                  30
0.20s                            1986.0                  30
-Jim
This is interesting Jim. Looking forward to more results
#43 terry59
terry59
Posted 17 September 2019 - 06:57 AM
That is what makes this forum invaluable. Real data, real tests, real results
#44 terry59
terry59
Posted 17 September 2019 - 07:08 AM
One thing you may run into is the rolling electronic shutter may interfere with the oscillation rate of a flat panel, and if it does, that might cause some problems. I have been using open (uncovered) aperture blue sky flats with my ASI183, with flat exposures of small fractions of a second along with bias calibration. So far things have been working nicely (save the occasional airplane in a flat frame. tongue2.gif
Thanks Jon....I really like this camera. It is beating the tar out of the KAF8300. As to flats, it is taking many, many seconds to reach the 30k ADU level when using the Flatman and that pattern persists regardless of what I've tried so I think you are correct as to the cause because I don't see anything like that with the KAF8300 and its mechanical shutter.
#45 terry59
terry59
Posted 17 September 2019 - 08:35 AM
I have rerun everything using an uncalibrated master dark. Here are the two results (no bias and bias with a pedestal of 100) with only a STF applied. I'm curious to know what people think
Edited by terry59, 17 September 2019 - 08:37 AM.
  • Jon Rista likes this
#46 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 17 September 2019 - 08:53 AM
Really hard to tell a difference between them given the forum image size restrictions. They both appear to have completely removed the amp glow. I'd be interested to hear what you see on your machine.
-Jim
Edited by kingjamez, 17 September 2019 - 08:54 AM.
#47 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 17 September 2019 - 08:57 AM
What do you suggest as the cause of Terry's bias having a 32 ADU higher median than his 300 second dark?
-Jim
#48 terry59
terry59
Posted 17 September 2019 - 09:09 AM
-Jim
I don't see any difference in the amp glow....both remove it completely as far as I can tell. I do find a slight visual difference in the result. It seems to me that adding a pedestal is an improvement
#49 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 17 September 2019 - 09:25 AM
I don't see any difference in the amp glow....both remove it completely as far as I can tell. I do find a slight visual difference in the result. It seems to me that adding a pedestal is an improvement.
Good deal. Since both are auto-SFT'd, I'd bet that you can make them both look the same by modifying the histogram. I think that the pedestal only needs to be roughly 40 to "work" so the extra is slightly making the whole image brighter.
My camera is running all day today taking darks and bias'. Hopefully I'll be able to reasonably replicate your results on mine soon.
-Jim
#50 terry59
terry59
Posted 17 September 2019 - 09:46 AM
-Jim
Thanks Jim....looking forward to seeing what you get
