My second attempt at narrow band - Elephants Trunk
3 replies to this topic
#1 AZ Maverick
AZ Maverick
  • Loc: Prescott, Arizona
Posted 14 September 2019 - 09:20 PM
This is my second attempt at a narrow band processed SHO image.
It turns out I have some serious tilt issues that are camera related and I think it needs to go back to ZWO to get fixed.
This image was mainly a test and is way short of data, I need to capture way more to get what I want.
Image details:
Skywatcher EQ6-R Pro mount
Explore Scientific ES80 Triplet
Orion Field Flattener
ASI1600MM Pro -15C
ZWO 7nm SHO filters
Astro-tech 60mm guide scope
ASI120MM-S guide scope
10 each 300 second exposures of Sll, Ha, Olll
Darks and flats
Aligned/Stacked in DSS
Processed in Photoshop - I'm still trying to get the hang of combining and adjusting the narrow band images.
  • Jim Waters, elmiko, lbim and 4 others like this
#2 View2
View2
  • Loc: Vancouver, WA USA
Posted 14 September 2019 - 09:32 PM
Looks really good. What is the problem you're having now? Have you checked to see if it's not the Orion field flattener giving you perceived tilt at the lower left there? It may just be a spacing issue.
Edited by View2, 14 September 2019 - 09:34 PM.
#3 View2
View2
Posted 14 September 2019 - 09:34 PM
And by the way for your second attempt at narrowband you did really good!
#4 AZ Maverick
AZ Maverick
Posted 14 September 2019 - 09:47 PM
Yeah, at first I thought it might be the Orion Field flattener not playing well in the image path - I went overboard and bought the Explore Scientific field flattener and still had the same problem (in fact the ES flattener was worse in another way, internal reflections).
Then I thought it might be caused by the ES (less than ideal) focuser, but I recently replaced it with a Moonlight CFL motorized focuser and the problem still exists.
And when rotating the camera with the Moonlight focuser the 'footballs' follow the camera.
A friend ran an image through the contour map and came up with this:
I don't know what else to do....
