EQ8 broken?
9 replies to this topic
#1 starhopper-de
starhopper-de
  • Loc: Germany, EU
Posted 15 September 2019 - 03:54 AM
Hello forum,
I got a EQ8 for 2 years in my garden observatory, yesterday a great issue appeared.
After a successfull one- or two star alignment, the displayed current coordinates are wrong and a goto fails in any case. Moving the mount with the handbox does not update the coordinates well. It seems to hang randomly.
I had to disable "auxilary encoders" to get it work again. A factory reset had not worked.
Has anybody encountered such a behaviour? Can I repair it myself?
Thomas
#2 StrStrck
StrStrck
  • Loc: Denmark
Posted 15 September 2019 - 02:09 PM
Perhaps the electronics have corroded? Or is your power source kaput?
#3 macdonjh
macdonjh
Posted 15 September 2019 - 08:57 PM
I had trouble with my HEQ-5, similar to what you describe, but not exactly the same.  When I talked to Orion tech support they recommended updating the hand controller firmware.  That seemed far fetched to me, but I tried it and it worked.  Perhaps it will help you, too.
#4 starhopper-de
starhopper-de
  • Loc: Germany, EU
Posted 16 September 2019 - 02:15 PM
Somebody told me, that the encoders are not sealed. Dust and oil can degrade performance of the encoder.
Is there a way to clean it?
Thomas
#5 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 17 September 2019 - 06:45 PM
Not only are the encoders not sealed, but the DEC encoder "wheel" (sticker on disk) can end up sitting in water when it gets into the metal housing around the encoder wheel.  Even a heavy dew can result in water in the housings.  That ends up ruining the stick-on encoders strip.  I have replaced a couple of those and drilled holes in the lowest part of the housing so that water can always get out.  The disks are a pain to get and a pain to install.
#6 OzAndrewJ
OzAndrewJ
Posted 17 September 2019 - 07:14 PM
Gday Thomas
As Ed noted, the encoders are not sealed at all and get covered in grot/deteriorate/corrode badly
They are not required for normal operation so you should just turn them off.
#7 StrStrck
StrStrck
  • Loc: Denmark
Posted 18 September 2019 - 12:26 AM
Gday Thomas
Gday, Andrew. What are the encoders for? Why are they not important?
#8 OzAndrewJ
OzAndrewJ
Posted 18 September 2019 - 12:41 AM
Gday Bjorn
The true position of the mount is determined by the motors microstep count relative to home, but this "home" can be changed as required
The encoders in the EQ8 ( And EQ6/5) are very coarse ( around 80 arcsec/ pulse for the EQ8 and 250 arcsec per pulse for the others )
They are only really used when "freedom finding", ie if you declutch the axes and manually slew around, they will keep your alignment "roughly" accurate ( by changing the microstep datum point ), but it may be several arcmins off. This is OK if rubbernecking, but not if you are synchronised with a planetarium program and require accurate positioning data.
The encoders have nothing to do with tracking rates etc, but as noted above, they can automatically change the microstep baselines if they trip certain limits, ie even tho the mount hasnt moved from target, the encoder can tell the system it has moved and adjust its datums without asking :-)
As such, unless you are rubbernecking, they really are not required.
Edited by OzAndrewJ, 18 September 2019 - 12:42 AM.
#9 StrStrck
StrStrck
  • Loc: Denmark
Posted 18 September 2019 - 05:12 AM
Gday Bjorn
Ah, thanks for the clarification! Good on ya!
#10 etatcloudy
etatcloudy
Posted 16 May 2020 - 02:46 PM
Last few times using my Orion HDX110 (EQ8) has been nothing but a huge aggravation, firmware updates, etc..   After a 2 star alignment then go to one of those same stars and it was nowhere near..  also when going to an object it would speed up then slow then speed up several times...  The firmware/software stinks, it should have notified me of the errors, or something instead of acting like everything was just fine.. I finally realized the encoders had to be going bad.. after taking off the covers noticed they do have a protective paint or covering like urethane, but it was degrading into dust which caused the problems!  I cleaned off with paper towels and acetone, lots of elbow greese to get off the defective coating..  I got maybe 80% off before giving up, put the mount back together and goto worked perfectly first try..  how long they will last now?  Maybe just turning them off is easier solution..  but the encoders are a main reason I bought the mount.. err.
