Gemini 2 ASCOM Driver Update?
2 replies to this topic
#1 Rockinrod
Rockinrod
Posted 15 September 2019 - 09:20 AM
I have a Losmandy G11 with Gemini 2 system...I have had this since May 2017...had a tough time getting this thing communicating with my computer at that time,  but has since been working fine until all of a sudden this morning when I wanted to go into my PHD2 guiding program to install some dark frames, I kept getting the ASCOM driver has a problem connecting, error..
I'm not sure what it could be! Are there new drivers out now? I have never updated this since 2017...Hand controller says, Mainboard firmware Built March 12, 2017 Level 5.21
I uninstalled PHD2, and did a fresh install, that didn't help... Battery seems to be okay...
Ethernet Addresses:
IP Address:192.168.0.111
Default gateway: 192.168.1.1
Thanks for any and all help. I'm dead in the water!
Rodney
#2 Rockinrod
Rockinrod
Posted 15 September 2019 - 09:59 AM
OMG..! This is crazy...!! Okay, I have my scope and mount sitting in the dining room, ok...I have everything connected to it, as if I was outside imaging, everything going...But it will not connect. I'm getting the error message, 'Gemini not Found' Will not Connect'
Okay, so I take the Gemini console and HC into my office, put it on my desk, connect everything except the servo motors. Now the dang thing is connecting! I did this two times, same result...What, it doesn't like the dining room?? As absurd at that sounds!
So if there is a problem in one of the drive motors would this cause ASCOM drivers not to connect?, Hmmm...I have Gremin in here someplace it seems.
I dare say that I'm the only one who has ever had this problem..
#3 GolfSierra
GolfSierra
  • Loc: Michigan North of 45
Posted 18 September 2019 - 05:44 PM
By chance was the Gemini Ascom interface all ready running, meaning it was active on the task bar before you opened SGP?  I had a connection issue because I had set it to auto start in Windows and it would show being active on the task bar prior to running SGP, that would cause a conflict when trying to connect. No issues since just letting SGP start the connection.
