Splitting Delta Cygni with small scopes
double star observing observing report
26 replies to this topic
#26 Jon Isaacs
Posted 25 September 2019 - 04:29 AM
A little story:
I like ST-80s, they're simple, inexpensive and versatile and I think they make good beginners scopes, they're about one half binocular and one half telescope.  They're not very good planetary-double star scopes but they're passable and show the moon reasonably well.  I buy them used and give them away..
The best one I've ever had is an older Celestron version that came on an EQ mount.  I've owned a couple of them but this one was different, it has a metal objective cell that threads to the tube and a metal dew shield.  I fitted it with a 2 inch focuser and my recollection is that I was able to split delta Cygni with it.  I had loaned it out about a year ago and I just received it back in the mail on Monday.  In light of this thread, I was eager to see if I could split delta Cygni...
I probably spent about an hour swapping eyepieces, seeing if I could eek out the split. I went as high as 230 x and there were times when I thought I might be seeing something but I never made the split.
Over to the double-double, I could split the one but not the other.  Frustrated, I went inside and got my WO 80mm F/7 FD and pointed it at delta Cygni.. No split.  No Cassini division.  This was very unusual, these are normally easy.  I went inside and got the 120mm F/7.5 ED, it normally provides clean, crisp views and has an easy time of delta Cygni.. No split, barely see the Cassini.
Bad seeing.  Delta Cygni in the ST-80 will have to wait.
  • Astrojensen, Sasa, Bonco2 and 1 other like this
#27 db2005
db2005
  • Loc: Living in Denmark, under Bortle 5 skies.
Posted 29 September 2019 - 07:55 AM
I took up the challenge of splitting Pi Aquila (1.4 arc seconds separation) with my 3" APO a few nights ago. As expected, no split, but I did see distinct elongation and a peanut-like shape with occasional hints of darkening between the two components. Magnification was around 190x.
These challenge-stars are so much fun!
  • Sasa, Bonco2 and rugby like this
Also tagged with one or more of these keywords: double star, observing, observing report
