Good extremely compact mount?
17 replies to this topic
#1 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 16 September 2019 - 10:57 AM
I like my C90 and ST80. But I haven't really got anything suitable to mount them on... either I use my Astroview mount which is so large I might as well use a larger telescope, or I use a photo tripod that is miserable and terrible to use.
What's a good ultra-portable mount for small telescopes? Something rugged and compact... lightness isn't as important as packed size. But also, reasonably pleasant to use. And preferably not too expensive (ideally not over $250-300 unless it has to be).
#2 db2005
db2005
  • Loc: Living in Denmark, under Bortle 5 skies.
Posted 16 September 2019 - 11:13 AM
I'm thinking Vixen Porta II on APP-TL130 tripod.
The APP-TL130 tripod is quite compact when collapsed. And the Porta II is about the most pleasant-to-use mount I have tried. It even has slow-motion controls.
#3 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 16 September 2019 - 11:19 AM
Vixen Porta Mount, ES Twilight, Orion VersaGo II....
#4 vtornado
vtornado
  • Loc: Northern Illinois
Posted 16 September 2019 - 11:26 AM
An 80 f/5 will ride on an AZ3.  This mount has is quirks, but I think they can be overlooked with
an 80 f/5.  This mount is now being marketed as celestron heavy duty alt-az mount.
The es tw1 or portamount will work very nicely too, more money and bigger.
I think there is a mini porta, I don't have it and cannot speak to it.
I just sold a AZ3 head here for $20 here, so you can probably pick one up used, if you can find or
make legs for it.  Shipping those would be expensive.
#5 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 16 September 2019 - 11:32 AM
I'm definitely hoping for something smaller than a Twilight mount. Ideally it should be small enough to fit into a backpack, or fly with.
#6 Hesiod
Hesiod
Posted 16 September 2019 - 11:34 AM
Porta or Travel Porta are nice options: with the adpater can use photographic tripods which are smaller than the APP-TL130 (but also more expensive).
Otherwise could look for a MiniGiro mount (the one here depicted is not the MiniGiro; a very similar mount is also the Berlebach Castor):
The head is smaller than a man's fist and weighs around 1kg, but the actual result depends on the tripod you pick/own/adapt. Also, no slo-mo knobs, if are fond of them.Those heads sell for 170€-220€ (depends on the accessories such as double clamps or counterweight rod), and for a suitable tripod may think to add 100€ or so (given the size of the tubes you want to use do not need a "boutique" model to attain good stiffness).
Personally am very fond of ballheads:
I have the previous model of this one https://www.teleskop...Tragekraft.html
and for this kind of work is good (even if not smaller than the mini T mount), even if my unit is mechanically very rough and rather unfit* for its designed purpose (photography) except at short exposures. In any case is much cheaper than any half-decent alt/az mount I can think of
*can not be reliably locked, but it is not an issue anymore if has to be used with clutches fully released. I had however to clear from its sticky glue-lubricant and apply a lithium-based grease
  • eros312 and johrich like this
#7 Wouter1981
Wouter1981
Posted 16 September 2019 - 12:24 PM
I use this head on a phototripod. It's a good mount but rather sensitive to balance the telescope
https://www.teleskop...to-tripods.html
#8 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 16 September 2019 - 12:27 PM
I really like the look of that. Any US vendor, or should I just import one if I decide to get it?
#9 dwmedic
dwmedic
  • Loc: Oxford,Ks
Posted 16 September 2019 - 12:41 PM
Stellarvue M1V same as the TS-Optics
#10 Don W
Don W
    demi-god and Chairman of the Finance Committee
  • Loc: Wisconsin, USA
Posted 16 September 2019 - 03:55 PM
Here's a thread on a good small mount, the Skywatcher AZ GTi Goto:
https://www.cloudyni...oto-wifi-mount/
#11 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 16 September 2019 - 04:24 PM
That also looks really nice.
#12 Paul Hooper
Paul Hooper
  • Loc: Cook County, IL
Posted 16 September 2019 - 06:03 PM
I am in the same market as you with my ST80 on a camera tripod. I am considering Stellarvue's M1V or M2. https://www.stellarv...llarvue-mounts/ I am also considering the dwarfstar from Universal Astronomics or the DSV-M or DSV-1 from Desert Sky Astro.
#13 Mitrovarr
Mitrovarr
  • Loc: Boise, Idaho
Posted 16 September 2019 - 07:08 PM
I think Universal Astronomics is gone. You might get one used.
#14 dwmedic
dwmedic
  • Loc: Oxford,Ks
Posted 16 September 2019 - 08:51 PM
Unfortunately Universal Astronomics is no longer in business.
#15 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 17 September 2019 - 11:22 AM
DwarfStar, MicroStar, M2, 501HDV, Bogen 3047.
#16 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 18 September 2019 - 08:39 AM
An EQ1 equatorial mount mount should fit in a backpack with the scope. At $119 from a major astro equipment dealer, it fits your budget. An additional $70 gets you the motor drive for the ra axis. The detechable legs would have to be strapped to the outside of the backpack.
  • hcf likes this
#17 trurl
trurl
  • Loc: North Carolina
Posted 18 September 2019 - 11:40 AM
I use my ST80 on a Stellarvue M1V with a carbon fiber tripod I got hand-me-down from my photographer wife. It has no slomo controls though so might be a bit of bother using it with the C90. This combination will definitely fit in a backpack.
I have an ETX90 and I use it on the Skywatcher AZ-GTi. The tripod which comes with that mount is a bit long for a backpack but you could strap it on or substitute another.
#18 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 18 September 2019 - 03:39 PM
My smallest mount is the UA Microstar Deluxe on a Benro tripod. Good for small cats and 80mm refractors. If you want something powered then the iOptron Cube II or with more capacity and go-to the Orion Star Seeker IV. the SW AZ GTi looks good also but I don't have one of those.
