Stellarium V 0.19.1
19 replies to this topic
#1 iandh2010
iandh2010
  • Loc: England
Posted 16 September 2019 - 07:19 PM
Hi Guys,
Hope this is posted in the correct forum!
I have just downloaded Stellarium 64 bit V 0.19.1 and I am just setting it up on my new computer.
Can anyone tell me where they have moved the settings window that enable the selection of observing locations and also select from a list of well known sites, as well as defining ones own.
I think that it looks good and has certainly cured the problem of NGC7662 and NGC2392 not being shown correctly, for some reason!
I had set up a number of presets for observing sites so would like to be able to  set these up again in the new version.
Advice greatly appreciated!
Regards
Ian
#2 PatrickVt
PatrickVt
  • Loc: Vermont, US
Posted 16 September 2019 - 08:15 PM
Those icons are on a popup sidebar on the left side of the screen.  Just hover near the lower part of the left sidebar and the icon bar of settings will slide out.
Patrick
#3 catalogman
catalogman
Posted 16 September 2019 - 08:21 PM
<snip>
<snip>
The error was probably copied correctly from HyperLeda:
NGC 2392 = PGC 2860341
NGC 7662 = PGC 165926
-- catalogman
#4 iandh2010
iandh2010
  • Loc: England
Posted 17 September 2019 - 08:56 AM
Hi Patrick,
Many thanks, I knew that the menus hide off the display until you mouse over them but I thought that I used to set up the locations by clicking what I have always thought of as the "compass" icon. I now realise is probably a astrolabe "calculations"  icon.
I now realise that the top icon is a compass direction rose for "location".
Doh..................
  • PatrickVt likes this
#5 iandh2010
iandh2010
  • Loc: England
Posted 17 September 2019 - 09:01 AM
-- catalogman
Hi Catalogman,
Those particular errors have been there for quite some time, on many previous releases of Stellarium. I first noted them last week on my older version 0.16.1 and also my friend's 0.18.??
Is there is a formal way of advising the Stellarium developers of such things?
#6 Alexander Wolf
Alexander Wolf
    Stellarium
  • Loc: Barnaul, Siberia, Russia
Posted 17 September 2019 - 11:10 AM
-- catalogman
NGC 2392 != PGC 2860341 - confirmed and fixed (the fix will be available in v0.19.2)
NGC 7662 = PGC 165926 - it's correct record
#7 catalogman
catalogman
Posted 17 September 2019 - 06:38 PM
Actually, many planetaries (including all of them in the NGC/IC) have PGC numbers. (See att. list.)  For
consistency, Stellarium should either keep them all or remove them all.
I may have been wrong to suggest that display problems with some objects are due to clashing identifications.
In my check, several planetaries (noted in the attachment) displayed only the green search reticle with no label
and no symbol -- they had no PGC label to clash with, so this is not the source of the display problem. (I used
Stellarium 0.19.0 on a live DVD of Astronomy Linux 19.04.)
-- catalogman
#8 obrazell
obrazell
  • Loc: United Kingdom
Posted 17 September 2019 - 08:05 PM
Interesting because if you ask SIMBAD or NED for those PGC numbers they return nothing so it looks like they have been edited out. Similarly SIMBAD gives no cross reference under NGC 2392 for any PGC/LEDA number.
Owen
#9 Alexander Wolf
Alexander Wolf
    Stellarium
Posted 17 September 2019 - 11:29 PM
-- catalogman
What is the source for cross-identification for NGC and PGC subset in attachment? For example I've check first cross-id line - NGC 40 = PGC 2923327 - and I did not find this cross-id nor in SIMBAD, nor in NED. I've checked few other cross-id lines and I didn't find cross-id data in SIMBAD and NED too.
#10 beggarly
beggarly
  • Loc: Belgium
Posted 18 September 2019 - 03:36 AM
https://cseligman.co.../atlas/ngc0.htm
NGC 40 = "PGC 2923327" - quote "... the PGC designation is essentially useless..."
A querry on http://vizier.u-strasbg.fr/
for PGC shows this result: VII/237, 9.833e+5 records, HYPERLEDA. I. Catalog of galaxies (Paturel+, 2003)
for LEDA                        : VII/242, 7.532e+5 records, LEDA galaxies with DENIS measurements catalog (Paturel+, 2005) Catalog
Both catalogs contain PGC identifiers.
http://leda.univ-lyo.../param/pgc.html
Edited by beggarly, 18 September 2019 - 10:18 AM.
#11 catalogman
catalogman
Posted 18 September 2019 - 02:00 PM
That's an important omission, sorry!
The source of the NGC/IC=PGC numbers in the attachment is HyperLEDA:
http://leda.univ-lyon1.fr/search.html
Type in the NGC/IC Object designation and click on the "LEDA (extended display)" button.
The PGC number displayed in the upper-right corner is an internal PGC number which
may not be recognized in other databases:
These internal numbers aren't meant to be used -- they're placeholders for objects that
were later found to be planetaries (object type = 'p'). What I don't understand is why
so many of them remain in HyperLEDA.
-- catalogman
#12 JoeInMN
JoeInMN
  • Loc: Minneapolis, MN, USA
Posted 21 September 2019 - 02:39 PM
Hello Mr. Wolf,
Running 0.19.01 on Linux Mint 19.1 Cinnamon here. I have an ongoing minor issue with the Oculars plugin; this may or may not be in your purview, but maybe you can help straighten it out... Selecting a telescope seems to cause incorrect magnification in the displayed image, though the numbers shown in the control panel look OK. The workaround is to then select a different ocular, which seems to correct the image, and then re-selecting the original ocular. Changing the ocular works fine from that point on, until a different telescope is selected; that will glitch the image again, requiring an ocular juggle to correct it as before. I call it a minor issue because the workaround is so easy, and I don't know whether other users have run into this, or whether it's just me...
Attached screenshot should enlarge when clicked.
Thanks to the entire Stellarium development team for producing this outstanding software!
Edited by JoeInMN, 21 September 2019 - 02:41 PM.
  • scottmm2012 likes this
#13 PatrickVt
PatrickVt
  • Loc: Vermont, US
Posted 21 September 2019 - 06:22 PM
Hello Mr. Wolf,
I have the same problem on Windows 64 bit.  I never mentioned because I figured others have already reported the problem.
Patrick
#14 Alexander Wolf
Alexander Wolf
    Stellarium
Posted 24 September 2019 - 12:35 PM
It's strange. Would you check the latest beta?
#15 JoeInMN
JoeInMN
Posted 24 September 2019 - 07:16 PM
I should say that I update via this daily build ppa (tried to unlink the URL part but apparently don't know how):
deb-src http://ppa.launchpad...um/daily/ubuntu bionic main
It could be that this is happening because I'm running some sort of bleeding-edge version... My package manager shows that I have this installed:
0.99.1+201909241519~ubuntu18.04.1
It's really the only issue that I can think of, that I run into with Stellarium.
Edited by JoeInMN, 24 September 2019 - 07:22 PM.
#16 Alexander Wolf
Alexander Wolf
    Stellarium
Posted 24 September 2019 - 09:37 PM
Could you share your oculars.ini file?
#17 JoeInMN
JoeInMN
Posted 24 September 2019 - 10:24 PM
This is from the ~/.stellarium/modules/Oculars directory...
[General]
arrow_scale=1.5
ccd_count=1
ccd_crop_overlay_size=250
ccd_index=0
enable_control_panel=true
hide_grids_and_lines=false
lens_count=2
lens_index=-1
limit_stellar_magnitude=true
ocular_count=9
ocular_index=2
oculars_version=3.1
require_selection_to_zoom=false
show_ccd_crop_overlay=false
show_resolution_criterions=false
show_toolbar_button=false
stars_scale_absolute=1.00
stars_scale_absolute_ccd=1.00
stars_scale_relative=1.00
stars_scale_relative_ccd=1.00
telescope_count=10
telescope_index=7
use_decimal_degrees=false
use_initial_direction=false
use_initial_fov=false
use_max_exit_circle=true
use_mount_autoset=false
use_semi_transparency=true
use_telrad_fov_scaling=true
[ccd]
0\binningX=1
0\binningY=1
0\chip_height=14.8
0\chip_rot_angle=0
0\chip_width=22.2
0\has_oag=false
0\name=EOS 450D
0\pixel_height=5.2
0\pixel_width=5.2
0\prism_distance=0
0\prism_height=0
0\prism_pos_angle=0
0\prism_width=0
0\resolutionX=4272
0\resolutionY=2848
[lens]
0\multipler=2
0\name=Barlow 2x
1\multipler=3
1\name=Barlow 3x
[ocular]
0\afov=7
0\binoculars=true
0\efl=10
0\fieldStop=0
0\name=10x50
0\permanentCrosshair=false
0\reticlePath=
1\afov=50
1\binoculars=false
1\efl=25
1\fieldStop=0
1\name=25mm Vixen NPL
1\permanentCrosshair=false
1\reticlePath=
2\afov=54
2\binoculars=false
2\efl=18
2\fieldStop=0
2\name=18mm Kellner
2\permanentCrosshair=false
2\reticlePath=
3\afov=55
3\binoculars=false
3\efl=15
3\fieldStop=0
3\name=15mm Plossl
3\permanentCrosshair=false
3\reticlePath=
4\afov=50
4\binoculars=false
4\efl=12
4\fieldStop=0
4\name=12mm Plossl
4\permanentCrosshair=false
4\reticlePath=
5\afov=50
5\binoculars=false
5\efl=7
5\fieldStop=0
5\name=7mm Plossl
5\permanentCrosshair=false
5\reticlePath=
6\afov=35
6\binoculars=false
6\efl=20
6\fieldStop=0
6\name=.965\" 20mm Huygens
6\permanentCrosshair=false
6\reticlePath=
7\afov=35
7\binoculars=false
7\efl=12.5
7\fieldStop=0
7\name=.965\" 12.5mm Huygens
7\permanentCrosshair=false
7\reticlePath=
8\afov=35
8\binoculars=false
8\efl=4
8\fieldStop=0
8\name=.965\" 4mm Huygens
8\permanentCrosshair=false
8\reticlePath=
[telescope]
0\diameter=152
0\equatorial=false
0\focalLength=1219
0\hFlip=true
0\name=6\" f/8
0\vFlip=true
1\diameter=152
1\equatorial=false
1\focalLength=756
1\hFlip=true
1\name=6\" f/5
1\vFlip=true
2\diameter=102
2\equatorial=true
2\focalLength=1000
2\hFlip=true
2\name=102mm f/10
2\vFlip=false
3\diameter=102
3\equatorial=true
3\focalLength=650
3\hFlip=true
3\name=102mm f/6.4
3\vFlip=false
4\diameter=80
4\equatorial=true
4\focalLength=560
4\hFlip=true
4\name=80mm f/7
4\vFlip=false
5\diameter=60
5\equatorial=true
5\focalLength=710
5\hFlip=true
5\name=60mm f/11.6
5\vFlip=false
6\diameter=60
6\equatorial=false
6\focalLength=415
6\hFlip=true
6\name=60mm f/7
6\vFlip=false
7\diameter=45
7\equatorial=false
7\focalLength=358
7\hFlip=true
7\name=45mm f/8 mirrored image
7\vFlip=false
8\diameter=45
8\equatorial=true
8\focalLength=358
8\hFlip=true
8\name=45mm erect image
8\vFlip=true
9\diameter=45
9\equatorial=false
9\focalLength=358
9\hFlip=true
9\name=45mm f/8 straight thru
9\vFlip=true
#18 Alexander Wolf
Alexander Wolf
    Stellarium
Posted 09 October 2019 - 11:24 AM
OK, it was hard, but I've found the "bad guy" for this strange behavior of Oculars plugin. So, the next problem - how fix one bug and do not introduce new one.
  • mikenoname and PatrickVt like this
#19 JoeInMN
JoeInMN
Posted 10 October 2019 - 01:18 AM
Thanks for working on this! Stellarium is amazing.
#20 iandh2010
iandh2010
  • Loc: England
Posted 10 October 2019 - 02:58 AM
Well done to Alexander and JoeInMN.
I agree that Stellarium is amazing and it will be even better with you guys working together on this bug!
