Help using Paramount MyT with SGP
6 replies to this topic
#1 Beechnut
Beechnut
  • Loc: Columbus Ohio
Posted 16 September 2019 - 09:10 PM
Hi all,
Am having some trouble getting my Paramount MyT to work with SGP.  I was wondering if someone could post the steps required to use the MyT with SGP in simple steps.  I'd really appreciate it.
#2 Beechnut
Beechnut
Posted 17 September 2019 - 09:55 PM
No one?
#3 Kriz1027
Kriz1027
  • Loc: Lone Tree, Colorado
Posted 18 September 2019 - 12:33 AM
You need to select the ASCOM driver for TheSky and use the attached settings.  Working for me right now.
  • psandelle and swannl11 like this
#4 Beechnut
Beechnut
Posted 18 September 2019 - 12:35 AM
Thanks, after I posted my last post I tried starting both programs in administrator mode.  That did the trick.   Thanks for the response.
#5 Kriz1027
Kriz1027
Posted 18 September 2019 - 12:36 AM
This is a really good resource to get started - http://www.alexastro...FirstWeekV3.pdf.
#6 Beechnut
Beechnut
Posted 18 September 2019 - 12:37 AM
Thanks,  downloaded it and will give it a read.
#7 Kriz1027
Kriz1027
Posted 18 September 2019 - 10:46 AM
Chris Woodhouse has done an excellent series of videos on SGP and also covers the setup of a SB mount.  It is well worth the time to watch the series.
http://digitalastrop...tup_Videos.html
I just ran my first sequence last night in SGP after reading the link above and watching the videos and everything worked perfectly...equipment connection, auto focusing, PHD2 guiding, etc. so either I'm really lucky or the time spent on learning SGP was well worth it.  Unfortunately I apparently overexposed the luminance and clip the histogram so I'll be reshooting it tonight with shorter exposures.  Always something else to learn.
