LX200GPS Left Fork Bracket Rubbing Arm
7 replies to this topic
#1 StargazerMax94
StargazerMax94
  • Loc: Salt Lake City, Utah
Posted 17 September 2019 - 01:45 AM
I have a older LX200GPS that I acquired from a gentleman. It's around a 2005 model year. The declination is VERY tight, like things aren't right with the bearing or something. I tried to move the tube up and down to possibly move the grease around to see if it would loosen up, but I heard a loud pop/bang sound. Then I took out the gear, clutch plate and the OTA is still stiff as can be. It's so tight you need two hands and some force to move the tube up or down in the forks. The gears, and clutches are disassembled and still won't move easily. I’ve noticed that the left fork arm saddle/bracket that holds the OTA and goes into the left fork arm is rubbing the side of the fork arm causing the resistance. But how do I fix that? Any suggestions how to remedy this problem?
#2 OzAndrewJ
OzAndrewJ
Posted 17 September 2019 - 02:53 AM
Gday StarGazerMax
The left fork arm stub axle/saddle plate is held by a single simple ball bearing on the inner side of the fork arm.
There is no way the saddle can rub against the fork arm itself unless something is wrong with the bearing
Might be time for some disassy.
#3 Skywatchr
Skywatchr
  • Loc: North-Central Pa.
Posted 17 September 2019 - 07:19 AM
Why 2 threads on the same scope?
  • StargazerMax94 likes this
#4 StargazerMax94
StargazerMax94
Posted 17 September 2019 - 02:51 PM
Gday StarGazerMax
Found out this is what it is indeed. The axle that attaches the OTA to the left fork arm.
  • Skywatchr likes this
#5 OzAndrewJ
OzAndrewJ
Posted 17 September 2019 - 04:14 PM
Gday Stargazermax
I cant imagine what would do damage like that other than a big drop
Have you checked the collimation of the Optics to ensure the baffle isnt damaged etc.
#6 Skywatchr
Skywatchr
Posted 18 September 2019 - 09:07 AM
Gday Stargazermax
Actually you weren't totally wrong. Something is wrong with the bearing.  Well, the bearing "surface" anyways. I've never seen the axle snapped off like that before.
#7 Skywatchr
Skywatchr
Posted 18 September 2019 - 09:08 AM
Whoa!  Time to be searching for a bearing plate.  Use that picture in your "wanted" ad. And state what size your OTA is of course.
Edited by Skywatchr, 18 September 2019 - 09:10 AM.
#8 Skywatchr
Skywatchr
Posted 18 September 2019 - 03:59 PM
I'm going to BFSP next week. I'll keep an eye out for one and snag it if I find one. You never know what you'll find on the swap tables.  All I have is for the LX200 Classic and are a bit different than the GPS models.
