Howto ASI224MC
10 replies to this topic
#1 Marco 104
Marco 104
Posted 17 September 2019 - 12:22 PM
Hi, I got an ASI224MC and I tried to turn it on to check everything is working
So I installed drivers on my Win7 and the connected the camera (which is recognized) to the PC only, while on my desk
Then, I started ASICAP, selected the camera on the top-right part, started a video (10ms frames at 200 gain) and the outcome is a complete black video
Tried something similar on SharpCap 3.2 and it is not even able to create the video file (all frames are dropped) and with snapshot the answer is that the single frame capture failed
Once again, with SGP, completely black frame, no matter if the CCTV lens is installed or if the sensor is exposed
What am I doing wrong?
Marco
#2 GoFish
GoFish
  • Loc: Kentucky / Colorado
Posted 17 September 2019 - 12:32 PM
Increase the gain, and lengthen the time.  You should be able to see when you've increased the exposure enough in the live view.  No need to actually capture video while you are troubleshooting.
I, too, would have thought 10ms @ 200 would be enough, but maybe it just needs a few more electrons in the wells to show something lol.gif
#3 Marco 104
Marco 104
Posted 17 September 2019 - 12:38 PM
Still black increasing to 10s (and I'm into the house with plenty of light), the problem is not there, as I see all black because I'm not collecting frame at all, it looks they're all dropped, sort of communication problem
M
#4 Gipht
Gipht
  • Loc: Prescott Valley, AZ.
Posted 17 September 2019 - 12:46 PM
Some USB ports are not powered, and I believe a powered port is needed.  Usually a PC has at least one powered port.
#5 GoFish
GoFish
Posted 17 September 2019 - 01:06 PM
M
Ouch.  That should be plenty of electrons.
Suggest troubleshooting using SharpCap because that seems to be the defacto standard.
First, does SharpCap offer the option to use the native driver (if so, it will show the camera in a section labeled ZWO ASI Cameras rather than DirecShow or ASCOM)?
On physically small computers (Intel compute stick, e.g.), there is interference between WiFi and USB3, so I have to use USB2 when using my stick computer.  Have you tried both USB2 and USB3?
To Gipht's point, you might also try using a powered USB hub.
Looking into the business end of the camera, can you see the sensor?
I had a similar experience with my ASI294 last night (only time this ever happened) where it was just black, no matter what setting.  I shut down SharpCap, unplugged the USB cable, plugged the cable back in to hear the ding, then restarted SC.  Problem solved.  I'm guessing you tried that already, though.
#6 rkinnett
rkinnett
  • Loc: La Crescenta, CA
Posted 17 September 2019 - 01:55 PM
Do you have another cable you can try?
Also, I've had problems with my asi1600 and a few other ZWO cameras having mechanically unreliable USB ports.  If the cable is tensioned in the wrong way, bending in a specific direction relative to the camera, then either the camera driver doesn't register at all, or it registers but drops all frames like what you're seeing in SharpCap.  First make sure your cable is not strained in any way, and restart your software.  If that doesn't work, try gently bending the cable in various directions and restarting your software.  I think I may have even needed to reboot Windows to clear up a suspected (unconfirmed) driver issue.
Also try running the camera on another computer if you have access to one.
#7 StrStrck
StrStrck
  • Loc: Denmark
Posted 17 September 2019 - 02:10 PM
Or if you just happen to have an Android based tablet or phone new enough to have mini usb-c port, and a suitable cable, install the ZWO app. The tablet will power the camera and should show a picture, if the camera is working.
#8 Marco 104
Marco 104
Posted 17 September 2019 - 02:20 PM
I'm using a MacBook Air, both with OS X and with Win7 (Parallel), working on the 2 USB ports that I connect external HDD to, tried all the combinations, no way
On SharpCap, the 224 appears in the appropriate Cameras tab, as ZWO ASI224MC
Now I go searching for another cable
M
#9 GoFish
GoFish
Posted 17 September 2019 - 02:48 PM
#10 Marco 104
Marco 104
Posted 17 September 2019 - 02:49 PM
Tried with another USB3 cable and it still doesn't work
So, I tried with a USB2 cable and now it works
Marco
Edited by Marco 104, 17 September 2019 - 02:53 PM.
  • GoFish likes this
#11 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 19 September 2019 - 12:51 PM
Did you take the lens cap off? I made that mistake once or twice when trying out a new camera.
