Autostar Updater Being Fussy
1 reply to this topic
#1 StargazerMax94
StargazerMax94
  • Loc: Salt Lake City, Utah
Posted 18 September 2019 - 09:22 AM
I recently got an LX200GPS for cheap because it needs some repairs. One of those things is the firmware, it’s still on 1.3t. I want to upgrade to the latest 4.2L but two different computers are fighting me on 2 different things right now.
First I purchased a USB to RJ11 direct cable that is made for the LX200s by a gentleman here in the US. It essentially eliminates the serial connector in the middle. I’m using an old laptop on Windows XP, and AutoStar Updater 5.9.3. The telescope connects up right away, and when you hit Update Autostar, you select the hand controller, and then get from WWW. When it tries it reads this:
“ THE HOST NAME IN THE CERTIFICATE IS INVALID OR DOES NOT MATCH”
So I thought, okay, I’ll try different version of AutoStar Updater, all the same result.
Swapped computers then. Went over to my Windows 10 Surface Pro, latest version of AutoStar Updater, plugged the same cable in, connected right up to the scope, tells me the firmware I’m using currently, then when you go to update, it confirms you want to, then it reads this:
“CHECK AUTOSTAR CABLE OR TRY A DIFFERENT SERIAL PORT THEN POWER CYCLE AUTOSTAR AND TRY AGAIN”
Okay, nothing fixes that. However it does automatically put the scope in Download mode.
So I also tried StarPatch to see and kind of the same thing. Notices the scope, downloads the firmware from the internet but when it goes to try to update, it loses connection when it throws it into download mode.
Anybody have these problems? Ways to fix?
Edited by StargazerMax94, 18 September 2019 - 09:24 AM.
#2 OzAndrewJ
OzAndrewJ
Posted 18 September 2019 - 05:03 PM
Gday StarGazerMax
As it can find the mount and put it into download mode, it sounds like it is working
In the earlier mounts, you could only use the left rs232 port ( ie closest one to the Hbx port ) to do firmware loads
so what port are you using.
I strongly suggest using StarPatch to load patched 4.2g, ( vs load 4.2l ), as several people are reporting odd problems with 4.2l.
  • Skywatchr likes this
