EQ5-R Pro?
8 replies to this topic
#1 quantumpion
quantumpion
Posted 18 September 2019 - 12:11 PM
Will sky watcher be coming out with an upgraded HEQ5 any time in the near future like the EQ6-R Pro?
#2 skyward_eyes
skyward_eyes
    Vendor - Sky-Watcher USA
Posted 18 September 2019 - 12:27 PM
Nothing on the docket at the moment. If we did what would you guys want on it that the current HEQ5 does not already have?
Edited by skyward_eyes, 18 September 2019 - 12:27 PM.
#3 quantumpion
quantumpion
Posted 19 September 2019 - 08:50 AM
I'm not sure, what upgrades did the EQ6-R Pro get over the previous versions? Belt drive? Better gears/motors?
#4 ThatsMyCoffee
ThatsMyCoffee
  • Loc: Czech Republic
Posted 19 September 2019 - 11:01 AM
Mine is less than 2 months old.  Here's what I'd change:
-Connectors should angle down slightly, or at least be vertical.  Up makes no sense.
-Better quality hardware.  The plastic knobs & screws feel very cheap and bend easily.
-Quieter gears
-Shorter minimum height for the tripod
-Better quality castings for the leg ends.  (Mine couldn't sit level before I modified it.)
-Strengthened vixen rail.  The material is soft and gets little dents from each use.
-Include a power adapter.
-Mac compatibility for any software
And what I'd add for the future:
-Belt Drive
-Built in PoleMaster
-Hand controller with a display of at least 4 lines or an option with NO hand controller?  (Mine is only used to connect the computer.  I don't touch any settings or do an alignment with it.  Why do I need it?)
-Wifi or Bluetooth adapter built in.
#5 ThatsMyCoffee
ThatsMyCoffee
Posted 19 September 2019 - 11:42 PM
A double lock on each tripod leg too.
#6 Astrodymium
Astrodymium
    Vendor - Astrodymium
Posted 19 September 2019 - 11:52 PM
That would be interesting to have, they'd just need to put a USB port on the mount itself for computer connections.
Edited by Astrodymium, 19 September 2019 - 11:56 PM.
#7 GoFish
GoFish
  • Loc: Kentucky / Colorado
Posted 20 September 2019 - 12:00 AM
  • belt drives
  • carrying handle
  • USB input for EQMOD control (I’m thinking along the lines of a built-in ShoeString USB2EQ5 interface)
  • tripod spreader that can be stored on a tripod leg (allows the tripod to be folded completely without having a loose piece to misplace)
  • optional carrying/storage case
  • built-in USB hub
  • optional converter box (like StarSense for SW) to permit use of NexStar HC and Celestron accessories
#8 Rhinottw
Rhinottw
  • Loc: Aalborg, Denmark
Posted 23 September 2019 - 04:28 AM
  • Belt drive
  • Better Alt adjustment bolts
  • Transport handle
  • USB interface
  • Lockable power connector
#9 einarin
einarin
Posted 23 September 2019 - 04:48 AM
AZ-EQ5 PRO has belt drive and USB-to-Serial port.
http://skywatcher.co...n-wpier-tripod/
