Celestron Nexstar Focuser Motor + 3rd party mount control without pc using hc, also usb drops?
10 replies to this topic
#1 markm75c
markm75c
  • Loc: Pittsburgh, PA
Posted 18 September 2019 - 12:29 PM
I have the celestron nexstar focuser motor.  I went from an 8se on celestron mount to an edge 11 on cem120.
I can control it via usb in windows 10.  It worked well on the 8se at least.
A few questions:
I'm experiencing lag at times where the buttons on the web interface dont work and i have to either unplug it and plug it back in to stop it from moving or cycle the software.
Not sure if its a usb issue or an issue since i'm sending the usb through my cem120 mount (non powered ports on there).
I did apply 1amp of 12v power to the celestron unit, which i thought it needed anyway.
Secondary question was on the aux port on the unit, i thought i read a nexstar+ controller could connect directly and manipulate the focuser.  I tested that theory but the controller didnt turn on.
Thanks in advance on any of this
#2 Michael_Swanson
Michael_Swanson
    Author of The NexStar Users Guide
Posted 18 September 2019 - 09:34 PM
Regarding the first question, have you tried a direct USB connection from the focuser to the Windows PC?
Regarding your second question, you would only be able to use the NexStar+ hand control to control the focuser when everything is plugged into a Celestron mount (not an iOptron mount).
Best regards,
Mike Swanson
Author of "The NexStar Users Guide II"
Author of "The NexStar Users Guide"
Author of "NexStar Observer List"
https://www.nexstarsite.com
#3 markm75c
markm75c
Posted 19 September 2019 - 08:45 PM
Best regards,
Mike Swanson
Yeah this is how i have things connected.  (Its a bit tough at times when the computer is across the way and you are trying to adjust focus from there.  I guess at least a phone app would help)
It just seems to timeout randomly.  Actually, the celestronfocuserutility.exe seems to be sucking up 12% causing the cpu to get high in temp.  Its the first i've noticed this.
#4 Michael_Swanson
Michael_Swanson
Posted 20 September 2019 - 06:12 AM
Hi Mark,
If you are interested in reporting the high CPU utilization and timeout and providing direct feedback, you might want to join https://www.teamcelestron.com/ and post a report.
Best regards,
Mike Swanson
Author of "The NexStar User's Guide II"
Author of "The NexStar User's Guide"
https://www.NexStarSite.com
#5 markm75c
markm75c
Posted 20 September 2019 - 10:09 AM
Hi Mark,
Best regards,
Mike Swanson
Ill check that out and submit.
Mark
#6 markm75c
markm75c
Posted 23 September 2019 - 10:49 AM
Hi Mark,
Best regards,
Mike Swanson
I joined that group last week but when i view it, there is no way to post or no support area that i can see?   Any ideas on what i'm missing there?
#7 Michael_Swanson
Michael_Swanson
Posted 23 September 2019 - 08:43 PM
The moderator needs to approve you which takes a couple of business days.  It has been many years since I went through that but I think you will receive an email message with instructions about posting and beta testing in general.
I'll email the moderator directly - can you provide the user name you selected for the site?
Best regards,
Mike Swanson
#8 markm75c
markm75c
Posted 24 September 2019 - 11:30 AM
Best regards,
Mike Swanson
Ok thanks no problem.  My id there is "markm75"
Also, inconclusive but i think a good sign.. last nite i switched the baud rate on the com port for the focuser to 115,200 and i didnt have any lag or even cpu over usage.  Maybe i got lucky, unsure, it was only a brief test, ill try again tonight.
#9 Michael_Swanson
Michael_Swanson
Posted 24 September 2019 - 11:52 PM
Mark,
I've asked the moderator to look for and approve your account.
Best regards,
Mike Swanson
Edited by Michael_Swanson, 24 September 2019 - 11:57 PM.
#10 markm75c
markm75c
Posted 29 October 2019 - 10:40 AM
Mark,
Best regards,
Mike Swanson
Hey there,
My usb connectivity issues have returned it seems (where it randomly doesnt respond, disconnecting/reconnecting the usb may or may not fix things)...
At any rate, i was going to post on that forum, but it looks like i still cant.  If you have the ability to ping them on that, this would be great thanks.
Mark
#11 Michael_Swanson
Michael_Swanson
Posted 29 October 2019 - 11:52 PM
Hi Mark,
I just sent them another email.
Best regards,
Mike Swanson
