CGEM RA is hard to adjust
7 replies to this topic
#1 Tim Kimbler
Tim Kimbler
  • Loc: Florida
Posted 19 September 2019 - 09:01 AM
Folks I have a CGEM in perfect condition.  My issue is the RA is difficult to adjust when polar aligning.  It's very stiff and hard to move.  Anyone have a solution or recommendation?  I guess some type of plate or pads.  Thanks
#2 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 19 September 2019 - 09:11 AM
I bought a sheet of plastic from ScopeStuff (http://scopestuff.com/ss_poly1.htm) and cut it to fit, works great.  I hear that the same made from a plastic milk container works too.  Or maybe just smooth both surfaces with fine sandpaper will make a big difference.
#3 petert913
petert913
  • Loc: Portland, OR
Posted 19 September 2019 - 09:34 AM
Is the RA used in polar alignment?  I use only Alt and Az adjustments.  If it is AZ we are talking about
then yes, a teflon slip sheet would help.
#4 dcollier
dcollier
Posted 19 September 2019 - 09:41 AM
I sanded mine with 400 grit sandpaper on both surfaces and then used stick drawer lubricant, problem solved.
            -Dave
#5 darkcloud
darkcloud
Posted 19 September 2019 - 11:50 AM
I don't have a CGEM, but on other mounts I have used, I put a couple of CD's between the plates.  Don't know if the center will fit the CGWM or not, but it quick and cheap if it does.
  • mich_al likes this
#6 Tim Kimbler
Tim Kimbler
  • Loc: Florida
Posted 19 September 2019 - 02:33 PM
Fabricating a slip plate seems like a good idea.  I ordered a sheet of UHMW from Amazon, 12x12,1/8.  Thanks for the suggestions everyone.
#7 eacmen
eacmen
  • Loc: Maryland, USA
Posted 19 September 2019 - 05:34 PM
I did the same thing but with thinner Teflon sheet. I only needed to use one. Two would probably be smoother though.
Sent from my iPhone using Tapatalk
#8 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 20 September 2019 - 10:04 PM
I find that loosening the main 12 mm threaded mount attachment rod just a bit makes adjusting AZ a lot easier. Once PA is set I retighten the 12 threaded rod, then tweak the PA once more if needed. Usually only ALT needs tweaking, if any is needed.
Likewise if I do ASPA I will temporarily loosen the 12mm rod, and carefully retighten when I’m done.
