What should I do?
2 replies to this topic
#1 2Barrel
2Barrel
  • Loc: S. Jersey
Posted 19 September 2019 - 02:44 PM
Hello folks.
Dont know what do do here so I'm asking for help.
I just purchased a Celestron electronic focuser and I already have a reducer for my 8 inch edgehd.
I also have a cannon T3i along with the OTOAG. I'm at the proper spacing of 105mm.
My question is about collimation.
Should I collimate the scope using a high powered eyepiece or should I collimate using the intended imaging train including reducer?
Any help would be appreciated.
Mike K.
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 19 September 2019 - 03:18 PM
I never collimate an SCT with extra optical parts in the train. Because if you do you will not know if everything is OK or if things are out and you just over-corrected to bring it closer to correct. You want to start with everything in the optical train at zero so in case you add a part that is out you will know its the culprit.
  • pgs/sdg and 2Barrel like this
#3 2Barrel
2Barrel
  • Loc: S. Jersey
Posted 19 September 2019 - 09:14 PM
That makes sense. Thanks for the reply.
