Need Help Mounting iOptron SkyGuider Pro On Meade Standard Field Tripod
12 replies to this topic
#1 Steve Saturn
Steve Saturn
  • Loc: San Diego, CA
Posted 19 September 2019 - 10:40 PM
Hi All,
I just purchased an iOptron SkyGuider Pro and I'd like to mount it on a Meade Standard Field Tripod. What kind of hardware/adapter will I need? Thanks for your help!
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 20 September 2019 - 12:46 AM
Can you send me some Meade tripod pictures and I will come up with something for you.  Are you using the SkyGuider Pro wedge?  What about the DEC bracket and counterweight?
I have the SkyGuider Pro but not the tripod.
#3 Steve Saturn
Steve Saturn
Posted 20 September 2019 - 08:59 AM
Hi Jim, thanks a million for your reply! I should be receiving the SGP in the mail today, and I'm picking up the tripod tomorrow. I'll post some pics when I get it, but in the meantime I'll try to post a pic from the web. I will be using The SGP wedge and Dec bracket with counterweight.
#4 Steve Saturn
Steve Saturn
Posted 20 September 2019 - 10:40 AM
Hi Jim,
Here's an image of the Meade Standard Field Tripod. I've read that the center bolt is 1/2" x 13tpi.
#5 Jim Waters
Jim Waters
Posted 20 September 2019 - 12:26 PM
You may have problems with this tripod.  If you will be using the SkyGuider Pro DEC Bracket and weights its unlikely that the bracket / weights will clear the base of the tripod.  You will have to try it out.
You will need to find a machine shop that will rethread the end of the existing tripod bolt to fit the base of the SkyGuider Pro wedge.  The wedge takes a 3/8 20 bolt.  I think the tripod bolt is larger - 1/2 20???  You may also have to cut some of the bolt off.
You may have to raise the wedge off the tripod base so the DEC Bracket / weight clears the base of the tripod.
Edited by Jim Waters, 20 September 2019 - 10:47 PM.
#6 Steve Saturn
Steve Saturn
Posted 20 September 2019 - 06:53 PM
Thanks Jim. I've been looking for adapters, but I hadn't thought about the counterweight clearance issue.
What mount/tripod are you using for your SGP and are you pleased with it?
Sent from my SM-G930P using Tapatalk
#7 Jim Waters
Jim Waters
Posted 20 September 2019 - 08:11 PM
I use this...  I got it used off CN.
https://optcorp.com/...um-tripod-25161
https://www.vixenopt...pod-p/25161.htm
My Star Adventurer setup.
Star Adventurer Mount
Edited by Jim Waters, 20 September 2019 - 08:12 PM.
#8 Steve Saturn
Steve Saturn
Posted 20 September 2019 - 09:41 PM
Thanks Jim. I'm rethinking the tripod...
#9 Jim Waters
Jim Waters
Posted 20 September 2019 - 10:05 PM
BTW - I see that you are in San Diego.  I get all my washers, screws, bolts ...etc from Ace Hardware.
#10 Poochpa
Poochpa
  • Loc: Buffalo Burbs, NY
Posted 21 September 2019 - 12:33 PM
Jim,
How did you adapt the Vixen tripod’s metric size bolt to the 3/8” sized wedge?
#11 Jim Waters
Jim Waters
Posted 21 September 2019 - 12:55 PM
I got another bolt at Ace Hardware and a few washers.
#12 Poochpa
Poochpa
Posted 21 September 2019 - 09:05 PM
Jim,
The bolt on my Vixen HAL is captive. Your's isn't?
#13 Jim Waters
Jim Waters
Posted 21 September 2019 - 09:36 PM
Should have a 'C' clip ring on top?
I was able to remove my bolt.
