Losmandy GM-8 / G11 motors interchangeable?
8 replies to this topic
#1 macdonjh
macdonjh
Posted 21 September 2019 - 03:06 PM
I did a quick, and not exhaustive, search in the old posts but didn't find an answer to this so here it goes:
I have a G11 with Digital Drive and stepper motors.  I have a GM-8 with Gemini I and servo motors.  Can I simply swap the kits?  I looked on Losmandy's website and I think the motors are interchangeable, I know Gemini is interchangeable, but I don't think the Digital Drive is interchangeable.  If I wanted to swap the kits, I'd have to buy a GM-8 Digital Drive PCB.  Correct?
I have also sent an e-mail to Losmandy asking the same question.  I'll post their reply here.  I posted here anyway because CN members are often faster to respond than manufacturers.
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 21 September 2019 - 03:11 PM
Can't answer your question.  Have you posted here?
https://groups.io/g/...dy_users/topics
#3 Nippon
Nippon
  • Loc: Central Florida
Posted 21 September 2019 - 03:15 PM
The Losmandy 492 digital drive system motors, cables and hand control for the G11 and GM8 are the same but the main drive board is different is my understanding.
#4 Jim Waters
Jim Waters
Posted 21 September 2019 - 03:17 PM
Yep
#5 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 21 September 2019 - 03:48 PM
Are the drive boards really different or isn't it the case that only the master clock needs to change on the main drive board between G8 & G11?
#6 Jim Waters
Jim Waters
Posted 21 September 2019 - 04:30 PM
I am pretty sure the FW is different on the two boards.  Call Scott Monday and ask.
Edited by Jim Waters, 21 September 2019 - 04:32 PM.
#7 GolfSierra
GolfSierra
  • Loc: Michigan North of 45
Posted 21 September 2019 - 05:43 PM
There is a chip on a 492 main board that is labeled 8 or 11 as appropriate.
#8 mich_al
mich_al
Posted 21 September 2019 - 06:56 PM
That would be the firmware, easily swapped since it's on a socket.  That means the boards are the same.
#9 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 22 September 2019 - 12:33 PM
The Gemini motors are the same for both mounts.  The difference would be in the mount gear ratios which should be fixed by changing the firmware.
