IC63 - the ghost of Christmas past- 24 hours of narrow band data
9 replies to this topic
#1 pyrasanth
pyrasanth
Posted 22 September 2019 - 08:08 AM
The Moravian G3 16200 is a wonderful camera. However I suspect that it does not do as well on narrow band targets as my Atik 460. However the 460 does have a limitation and that is the sensor size. I wish Sony would have produced a bigger sensor with the same characteristics but I digress.
I found IC63 an incredibly faint target from my location. It may have been exacerbated by relatively poor transparency but I needed very long exposures to capture anything other than the HA. There was some SII & OIII but it was very faint. I could not capture anything other than RED RGB data as the proximity to bright stars was destroying the blue & green subs with bright off field star banding.
Ultimately I caught a mere smidgen of OII & SII data but it was there upon stretching the image. I realised that it would have perhaps taken at least 24 hours through each narrow band filter to capture anything significant in SII & OIII but the HA was pretty good.
The integration time are below. The telescope is the C14 at F7.7 with Moravian G3 16200 camera mark 2.
1x1 BIN
HA
4 x 1200 Seconds
26 x 1800 Seconds
OIII
4 x 1200 Seconds
SII
3 x 600 Seconds
2x2 BIN
HA 5 x 1800 Seconds
OIII 1 x 1200 Seconds
OIII 4 x 2700 Seconds
SII  1 x 1200 SEconds
SII  3 x 2700 Seconds
Totals
HA        60700  17 Hours
OIII      16800  4.6 hours
SII       11100  3 Hours
Filters Baader HA 3.5 nm Enforced
Chroma 3 nm
Baader SII 4.5 nm
All 50x50 mm square
I have not corrected the image for the Hubble pallet. There is not not enough OIII or SII data.
As always clear skies to you and let me know what you think of the image.
However I'm still not sure if it was worth the 24 hours of imaging time with the C14. I will do better with the RASA 11 when that is rolled out in the next few months. The etude is so much higher on that instrument which is needed on targets like this for the OIII & SII data.
  • Ptarmigan, R Botero, elmiko and 7 others like this
#2 baondayko
baondayko
  • Loc: Central Ohio
Posted 23 September 2019 - 09:09 AM
I'd never seen this before. Great image and very ghost-like.
  • Seanem44 and pyrasanth like this
#3 pyrasanth
pyrasanth
Posted 23 September 2019 - 02:19 PM
Thanks for your kind words. My capture does not do this object justice. I had so little SII or OIII data. I don't know if it was the conditions or my camera- only time will tell. I'm really looking forward to the new generation of mono large sensor CMOS cameras. They will be great for this type of imaging.
#4 lucam
lucam
  • Loc: Upstate NY, USA
Posted 23 September 2019 - 04:35 PM
There isn't much OIII and SII signal in there that I know of. IC63 and IC59 have reflection and emission components. The weak signal you are picking up in OIII is likely to be blue continuum signal from the reflection nebula more so than oxygen specific. If you combine RGB data with your Ha data, you'll be able to see the reflection component well outlined by the signal in the H-alpha emission line.
Edited by lucam, 23 September 2019 - 04:36 PM.
#5 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 23 September 2019 - 07:17 PM
You got me into the Christmas spirit! Nice image of IC63. cool.gif waytogo.gif
  • pyrasanth likes this
#6 R Botero
R Botero
  • Loc: Kent, England
Posted 24 September 2019 - 02:18 AM
I’m surprised you struggled to capture SII for this one given your scope aperture and the focal ratio you were imagining at. I used a Moravian G4/16000 earlier this month on this target and had good SII data after 7hrs. Ha was 11hrs and detail was good  but got nothing to show in OIII even after 6hrs. This was over the full moon cycle with a 6” refractor at f/8 from suburban London:
https://astrob.in/7cqr8b/H/
Roberto
#7 pyrasanth
pyrasanth
Posted 24 September 2019 - 02:25 AM
Roberto
I think a big factor may have been the weather. The sky was not very transparent. There certainly was SII data being seen but it was quite weak and needed 45 minute exposures at 2x2 bin to capture. I was using a 4.5 nm filter. I caught a very tiny smidgen of OIII but it was weaker than the SII. The OIII was captured with a 3 nm Chroma filter. I would stress that I needed more time on the SII as the image only has 3 hours. Your 7 hours would have helped the SII development.
#8 R Botero
R Botero
Posted 24 September 2019 - 03:08 AM
Indeed; more time always help.  I did enjoy some very good transparent skies with nice seeing but the Moon was full/waning.  Since we are into the new Moon phase, I'd encourage you to capture more SII data.  You have a very nice image that can be easily improved with more data.  If I get a chance I may capture some more blue which was coming in nicely after 2hrs.
Best wishes
Roberto
#9 pyrasanth
pyrasanth
Posted 24 September 2019 - 03:26 AM
Best wishes
Roberto
The weather is currently not good. I will try & capture more SII when the weather lets me. I'm having trouble with green & blue RGB data. I'm getting a lot of bright streaks on the images. This is perhaps because of a bright star just off axis that is spoiling the frames. I'm not seeing this with the red filter- only the green & especially the blue. I also see traces in the longer (2x2 bin 45 minute)  OIII exposures.
#10 R Botero
R Botero
Posted 24 September 2019 - 11:50 AM
I don't know if your shot above is a crop or not. If not, the bright star must be Navi (Gamma Cas) which illuminates the two nebula.  It's a blue subgiant.  It's a pain to deal with when processing shots including it and caused me problems in Ha where I had micro-lensing showing up in my 20 min exposures.
Roberto
