M33 - Triangulum Galaxy LHaRGB
4 replies to this topic
#1 BBC
BBC
  • Loc: North Carolina, USA
Posted 22 September 2019 - 06:13 PM
https://www.astrobin...v/0/?real=&mod=
Imaging telescope: Mallincam VRC-8
Imaging camera: Atik 383L+ mono
Mount: CEM60
Guiding telescope: Mallincam VRC-8
Guiding camera: Starlight Xpress Loadestar X2
Focal reducer: CCDT67
Filters:
  • Astrodon 36mm Tru-Balance E-Series Blue
  • Astrodon 36mm Tru-Balance E-Series Green
  • Astrodon 36mm Tru-Balance E-Series Red
  • Astrodon 36mm Tru-Balance E-Series Luminance
  • Astrodon H-Alpha 3nm
Accessories:
  • Atik EFW2 Filter Wheel
  • Atik OAG
  • Moonlite High res stepper motor and Mini-V2 controller
Software:
  • PixInsight PinInsight 1.8
  • Main Sequence Software Sequence Generator
  • PHD2
Dates:
  • Sept. 19, 2019
  • Sept. 20, 2019
  • Sept. 21, 2019
  • Sept. 22, 2019
Frames:
  • Astrodon 36mm Tru-Balance E-Series Blue: 18x600" -20C bin 1x1
  • Astrodon 36mm Tru-Balance E-Series Green: 18x600" -20C bin 1x1
  • Astrodon 36mm Tru-Balance E-Series Luminance: 36x300" -20C bin 1x1
  • Astrodon 36mm Tru-Balance E-Series Red: 18x600" -20C bin 1x1
  • Astrodon H-Alpha 3nm: 21x1200" -20C bin 1x1
Resolution: 2400x3100
Pixel scale: 1.085 arcsec/pixel
Integration: 19.0 hours
Avg. Moon age: 21.06 days
Avg. Moon phase: 61.15%
Bortle Dark-Sky Scale: 7.00
RA center: 23.464 degrees
DEC center: 30.657 degrees
Orientation: 89.960 degrees
Field radius: 0.591 degrees
  • eros312, PeteM, Tom K and 9 others like this
#2 Tom K
Tom K
  • Loc: Escondido, CA
Posted 22 September 2019 - 07:36 PM
Nicely done - I would be interested to learn from your PI workflow.
  • BBC likes this
#3 stargazer60
stargazer60
  • Loc: South Texas
Posted 22 September 2019 - 07:52 PM
Very nice, great detail and color separation.  Keep up the great work. waytogo.gif
  • BBC likes this
#4 BBC
BBC
Posted 22 September 2019 - 08:12 PM
Thank you, Tom.  Here is my workflow ...
Preprocessing:
  • Calibration with Flats and Darks on L, R, G and B. Calibration of Ha with Darks only.
  • Cosmetic Correction on L, R, G, B and Ha
  • StarAlignment w/ Nearest Neighbor pixel interpolation on L (lowest FWHM Red image as reference)
  • StartAlignment w/ Auto pixel interpolation on R, G, B and Ha (lowest FWHM Red image as reference)
  • Individual ImageIntegration on L, R, G, B and Ha with Sigma low 3.3, Sigma high 2.2 and low and high large scale rejection enabled (default settings)
Luminance:
  • Several iterations of DBE with various points to beat down light pollution in Lum
  • Deconvolution
  • Minor noise reduction with MLT w/ layer and first layer disabled
  • ArcSinhStretch, HistogramTransformation
  • HDRMT on extracted preview of galaxy - 7 layers, lightness mask, Small scale 8 (3) scaling
  • Apply extracted preview back into Luminance w/ PixelMath formula
  • CurvesTransformation adjustment
  • Set black point with STF and apply using HistogramTransformation
RGB:
  • Several iteration of DBE with various points on R, G, and B
  • ChannelCombination with R, G and B
  • PhotometricColorCalibration
  • MLT w/ 1 layer and first layer disabled
  • SCNR
  • ArcsinhStretch, HistogramTransformation
Finish:
  • LRGBCombination L to RGB image w/ lightness and saturation transfer functions lowered from 0.5
  • ColorSaturation to adjust reds and blues
  • Noise reduction with mask protection high signal - MLT w/ 1 layer and first layer disabled
  • Noise reduction with mask protection low signal - TGVDenoise L*a*b mode and applying both Luminance and Chrominance
  • MaskedStretch Ha image
  • Extract Red channel from RGB
  • PixelMath to combine Red and Ha image w/ formula ((HA * R_bandwidth) - (R * HA_bandwidth)) / (R_bandwidth - HA_bandwidth) and setting bandwidth of HA _bandwidth as per filter (3nm in my case) and manipulating R_bandwidth until a desire image is achieved
  • Apply HaR combined image back into RGB image with Pixel Math - R formula: $T + ((CombImg - Med(CombImg)) * BoostFactor), G and B as $T, BoosFactor was 0.75
  • ColorSaturation adjustments with low signal masked
  • UnsharpMask with low signal masked
  • Created new RGB image with ChannelCombination
  • MaskedStretch to new RGB image
  • Apply star mask to original RGB image to expose larger, brighter stars - those blown out by ArcsinhStretch
  • Overlay stars of new RGB image with PixelMath
  • Used GAME script to isolate larger stars and create mask
  • Apply star mask to image and use MorphologicalTransformation to reduce stars, followed by slight desaturation w/ CurvesTransformation
  • HDMRT again to higher signal of galaxy w/ galaxy mask applied
  • Slight boost of blue channel again w/ galaxy mask applied using PixelMath
  • Final ColorSaturation adjustments
  • Final black point and midtones adjustment w/ HistogramTransformation
Hope this helps!!
#5 Tom K
Tom K
Posted 22 September 2019 - 08:44 PM
Wow - that is something else!   My PI skills definitely need a tune up!
