Delicious Donuts in my pictures.
13 replies to this topic
#1 Eyeheartmono
Eyeheartmono
Posted 22 September 2019 - 08:20 PM
I’m quite new to astrophotography and I’ve spent a couple nights in pretty light polluted skies trying to find some brighter objects to do some exposures on. I’ve had many instances where my pictures from my CCD ( DSI-IV ) have produced a large donut in the center of the view doing 30-45 second exposures. I’m trying to isolate what is causing it.
I thought it may be dew at first but my heater seems to be working well.
Maybe humidity?
Any ideas? When I figure out how to post pictures I will try and get one up.
Any help to a newbie would be appreciated.
Thanks in advance.
#2 Eyeheartmono
Eyeheartmono
Posted 22 September 2019 - 08:38 PM
There we go
#3 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 22 September 2019 - 09:01 PM
That's too big to be a dust donut.  Looks like a reflection.  Check to see if something in the imaging train (extension tube, adapter, etc.) has some shiny bits on the inside...
  • jdupton likes this
#4 Eyeheartmono
Eyeheartmono
Posted 22 September 2019 - 09:05 PM
Hmm, I’ll check that. You say reflection, could this be from the moon? My scope was pointing almost at the zenith when I took these pictures and the moon was just rising at about 15 deg on horizon.
#5 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 22 September 2019 - 09:07 PM
it looks like a big spot of water, covering the optics...
#6 OldManSky
OldManSky
Posted 22 September 2019 - 10:56 PM
If you have a dew shield, probably not.
But if you have a light leak somewhere in your imaging train...maybe!
#7 Adun
Adun
Posted 22 September 2019 - 11:14 PM
My vote is for wormhole exit point.
  • OldManSky and Eyeheartmono like this
#8 Eyeheartmono
Eyeheartmono
Posted 23 September 2019 - 08:50 PM
Here are pictures of my image train, other then there being some debris on my diagonal I can't see much else wrong with it as it is rather new. Maybe i'll try putting a garbage bag over the image train to see if light is entering next clear night.I know the diagonal is probably the worst thing to have the camera attached to but it was the only thing i had to let the camera come in focus at the moment till some spacers arrive.
#9 RogeZ
RogeZ
Posted 24 September 2019 - 06:01 AM
You need to remove the diagonal and set the camera straight on the scope. Try that combination.
#10 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 24 September 2019 - 06:11 AM
I strongly suspect dew somewhere in the optical train....Ive seen it before many times on CN and this looks just the same.
#11 Eyeheartmono
Eyeheartmono
Posted 24 September 2019 - 06:29 AM
Thanks for the help everyone, as i said before i know the diagonal is not optimal  and spacers are in the works. I was having an issue with back focus.
Would wrapping another heater around the back of the OTA help? My only concern is trapping heat inside the optical train and in turn fighting with the cooling of the CMOS chip.
#12 geneva_min
geneva_min
  • Loc: Geneva Florida
Posted 24 September 2019 - 07:29 AM
I'm not giving advice on this.....I'm more asking.  Wouldn't flat calibration frames remove the issue regardless of what's causing it?
#13 Eyeheartmono
Eyeheartmono
Posted 24 September 2019 - 08:22 AM
I don’t think flats would remove dew on the sensor if that’s the case. That picture actually is about 20x 30 second exposers plus 10 dark frames. The ring was actually quite worse in individual frames.
#14 Eyeheartmono
Eyeheartmono
Posted 07 October 2019 - 10:55 AM
If anyone was wondering this was a user error, I moved the dew heater farther up the dew shield and it fixed the issue. Thank you for the help!
