Source for the small 1.5" vent fans on 10" RC telescopes
SCT equipment
6 replies to this topic
#1 Aubrey B
Aubrey B
Posted 23 September 2019 - 01:22 PM
It seems one of the most deep secrets is the source for the small vent fans in the TPO/AT/Orion et al 10 " enclosed RC telescopes. They are easy to push in because they are held in by two plastic arms. I broke one of mine and all I get from Orion is the run around. I need to know if anyone has found a source for them
#2 scopewizard
scopewizard
  • Loc: Alberta, Canada
Posted 23 September 2019 - 02:38 PM
It looks to me that the fans are 1.5" 12vdc fan. Check Amazon, similar to some computer fan found on some server boxes.
#3 macdonjh
macdonjh
Posted 23 September 2019 - 03:06 PM
Digi-Key
Mouser Electronics
#4 TomTTuttle
TomTTuttle
  • Loc: Pearl River, LA
Posted 28 September 2019 - 11:08 AM
You probably don't want 1U server fans... they're probably pwm controlled and include a tach (4 wires), and they usually turn up to 15000 rpm and make quite a bit of noise, plus they're over an inch long.  I'd suggest looking for a 4010 DC brushless.  They're easy to be had in 12v, and pull little power (0.1 - 0.2A) and Digi and Mouser certainly would have them, but they can also be found on AllElectronics.com   12V@0.08A! And $3.75 ... And they have rubber mounts, and fan guards $1 for either https://www.allelect...ling-fan/1.html
Edited by TomTTuttle, 28 September 2019 - 11:09 AM.
#5 ad701xx
ad701xx
  • Loc: Oregon, USA
Posted 28 September 2019 - 11:29 PM
They are probably 40mm fans being it's a Chinese made scope. You can get them in 10 and 20mm thickness. Just measure them and search Amazon, etc.
#6 zach540
zach540
  • Loc: Colorado Springs
Posted 04 October 2019 - 05:05 PM
Have you removed the fan yet?  There's likely a sticker on it with a part number you can cross reference.
#7 cturek
cturek
  • Loc: OFallon, MO USA
Posted 13 October 2019 - 06:38 AM
I finally remembered where I purchased two 18mm x 18mm x 4mm 5v dc fans to replace the Tempest fans on my EdgeHD 8. Try here:
https://www.pelonistechnologies.com/
They have fans, including micro fans, of all shapes and sizes.
Carl
Also tagged with one or more of these keywords: SCT, equipment
