Meade LX85 ( Crash test dummies required )
26 replies to this topic
#26 Riaandw
Riaandw
  • Loc: South Africa
Posted 12 October 2021 - 07:19 AM
Gday All
Is there anyone out there with an LX85 that knows how to use a multimeter to measure pins in a port and is willing to do so? ( A simple unpowered continuity test will be OK for the +12 and grounds )
A user recently plugged in a StarGPS lump and it got fried.
Also, part of the users PCB blew, but on measuring the voltages in the Aux port ( which supplies power to the lump ), he is registering that the ground and +12V pins are swapped relative to all other mounts.
I have attached a piccy of a std Meade control panel and what pins are +12V and what are ground for the Aux port.
If someone can check their port on the LX85 and confirm it is either opposite or the same as what i have attached, it would be most appreciated.
Still need this Andrew?
#27 OzAndrewJ
OzAndrewJ
Posted 12 October 2021 - 03:54 PM
Gday Riaandw
Nope. Several users confirmed it and Meade also confirmed it.
LX85s AUX ports are wired mirror image.
Early LX65s are also wrong but later ones got a revised board.
They put a white dot in the battery compartment to signify the later (correct) ones
but i always suggest users test for themselves
  • Riaandw likes this
