Meade LX200 8" GPS slewing issue
1 reply to this topic
#1 marsbase
marsbase
  • Loc: East PA
Posted 06 October 2019 - 09:20 AM
Hi Guys,
I have an older 8" Lx200 gps. 1 issue is the power switch does not work all of the time. When I switch it on there is no power. When I switch it off there is a blink from the red power led. After a few on off switchings it does power on. I can live with that if there is no easy fix.
The main issue is when doing the star alignment. The slewing is painfully slow. I tried changing the speed on the handset but it does not work with the alignment slewing. The speed settings do work after the alignment is done. Is there a separate speed setting for alignment?
Steve
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 06 October 2019 - 09:42 AM
No use for the switch, sounds like a new one is needed and maybe wire/connector checking.
Slew - Maybe. Somewhere in the menu there is I expect a Max Slew Rate and that may be set low, as in 2, 3, 4 area.
When you slew the setting will get over-ridden. The manual input/request will take priority.
Idea is that you run the scope a bit quieter although therefore a bit slower.
That is about all.
Time to dig in to the menu tree.
Odd looking Menu Tree in the manual:
Could be:
Setup - Telescope - Max Slew Rate.
But looks like:
Setup - Smart Mount - Telescope - Max Slew Rate.
Not come across the "Smart Mount" bit previously
Page 24, either way. LX200GPS-Manual
Edited by sg6, 06 October 2019 - 09:53 AM.
  • NickInSac likes this
